Unlocking all doors with SKS (Was: Deleted)
Discussion in 'Gen 2 Prius Main Forum' started by tracysbeans, Jan 20, 2006.
Thread Status:
Not open for further replies.
  1. tracysbeans
    tracysbeans Member
    979
    Wisconsin
    DELETING MY QUESTIONS AND COMMENTS IN THIS THREAD SINCE MODS WON'T DELETE THE THREAD AS I REQUESTED!
    Deep cleansing breaths everyone....
    The original question was about how to open the back doors with the SKS--apparently the question was intended to ask how to unlock all doors when one sks sensor equipt door was unlocked.
    TBs--it's a bit childish to delete your individual posts that way...low level passive aggressive at best. I told you that I would be happy to address individual posts you felt were offensive or that were attacks. That has been the policy used here, quite successfully, for over 2 years and will, unless Danny does a major 180 on the subject, stay that way.
    I clearly explained to you that there was valuable content in the thread that may be of use to others and that's why the entire thread would not be deleted.
    As it turns out you got the answer to the question you eventually asked. Others may get it here as well.
    Now, everyone else....Try to play nice. I realize that Tracy was doing a poor job of explaining her difficulties, but that doesn't mean you need to start circling the prey just b/c of a sign of weakness.
    Bottom line...if you want a good answer try to elucidate your question as clearly as possible. Explain the problem, explain solutions you've tried, and the specific feedback you desire. That is the best way to assure an answer that will be direct, helpful and polite. Also, however, if you don't get exactly what you want don't take a defensive posture, try to clarify. And Be Nice!! for goodness sakes.
  2. Dave
    Dave New Member
    340
    Santa Cruz, CA
    I believe the way it's programmed from the factory, if you unlock the driver's door, just that door unlocks. If you open the front passenger or rear hatch door, it unlocks all of the doors. If I want to unlock the rear doors, I either slide my hand behind the front passenger door handle to unlock all the doors and then open the rear door, or I open the driver's side door and push the unlock button on the arm rest. The first option is pretty easy. No need to fumble for the fob.
    I know that sounds convoluted, but I hope it helps.
  3. tracysbeans
    tracysbeans Member
    979
    Wisconsin
  4. tag
    tag Senior Member
    2,526
    Chicago
    Is there something in the 06 manual about holding down the LOCK and PANIC buttons on the fob for about 5 seconds? That's the way you change the default SKS unlock behavior on the 04/05.
  5. Dave
    Dave New Member
    340
    Santa Cruz, CA
    I personally don't think it's that hard to slip my hand behind the front passenger handle to unlock all of the doors.
  6. tracysbeans
    tracysbeans Member
    979
    Wisconsin
  7. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    there are smart key handles on the two front doors and the hatch. the rear doors don't respond to touch. no matter what the smartkey system is set to do
    you can set your smartkey to open all doors when you touch the driver's door handle, but you still have to touch the driver's door handle to open the rear doors. sort of like in other cars there's only a keyhole in the front doors and not the rear doors.
    nothing you can really do about this one, sorry tracy.
  8. tracysbeans
    tracysbeans Member
    979
    Wisconsin
  9. benighted
    benighted New Member
    530
    Westport, WA
    Not nearly as tough as fumbling with keys.
  10. tracysbeans
    tracysbeans Member
    979
    Wisconsin
  11. galaxee
    9,810
    465
    MD
    yes, you have to be in the range that the key can communicate with the car, because you're giving the car a command.
  12. tracysbeans
    tracysbeans Member
    979
    Wisconsin
  13. tracysbeans
    tracysbeans Member
    979
    Wisconsin
  14. mehrenst
    mehrenst Member
    439
    San Jose, CA
    I don't put anything like grocerys in the back seat. I don't relish the idea of cleaning the microfiber if something leaks. Instead I bought one of the Auto Bungee Nets for the Prius off eBay. Its great. Just put everything on the hatchback floor and pull the net over the top. :D It clips right into the rings used for the tire holddown.
  15. Frank Hudon
    Frank Hudon Senior Member
    4,147
    if you walk up to the rear of the car and put 1 finger on the touch strip for approx 2 seconds you'll hear all the doors unlock. Hold it for 3 seconds and the hatch will also unlock.
  16. Dave
    Dave New Member
    340
    Santa Cruz, CA
    If I had several bags of groceries in my hands I still have to pull the door open with the handle. It doesn't pop open on it's own.
  17. tracysbeans
    tracysbeans Member
    979
    Wisconsin
  18. tracysbeans
    tracysbeans Member
    979
    Wisconsin
  19. tracysbeans
    tracysbeans Member
    979
    Wisconsin
  20. Dave
    Dave New Member
    340
    Santa Cruz, CA
    I don't understand. If you touch the back of the OUTSIDE front passenger door handle, all doors unlock.
Thread Status:
