Unnecessary (& rough) running ICE
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Fubar XIII, Jul 10, 2024.
  1. sparky12
    sparky12 Junior Member
    22
    Virginia
    2021 Prius
    XLE AWD-e
    Sounds like an EGR valve to me... I'd change the valve and the cooler thingy on the the other side of it. You can clean it but it takes less time to replace it. Also remove the intake manifold and try to clean the small ports as well. They can clog up and cause rough running. Check the tube between the valve and the intake manifold too. The Car Care Nut discussed that on one of his vids..
  2. Fubar XIII
    Fubar XIII Member
    72
    42
    Metro Detroit
    After a lot of detective work, the source of the roughness was found to be:
    A broken motor mount.
    I was talking with a mechanic when I took it in for an oil & filter change and he suggested we try something after the tires were put back on.
    Lifted the engine just enough to take the load off the frame, vibration gone instantly. Released it, vibration back.
    Part ordered (took a month) & installed and now my Michigan Blue moneymaker is smooth as a baby's butt once more.
    avidtravellerhkg likes this.
