Unplug EGR Valve
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Paladain55, Oct 20, 2021.
  1. Paladain55
    Paladain55 Active Member
    414
    172
    The South
    I consider it permanently fixed now so that's why. No more cleaning egr. I know there are some rule sticklers here who prefer to have the system fully functioning as intended but it still takes a couple hours to clean that crap. Now I never have to ever again. Lol
    I did clean the manifold though and it got it fully functioning, but then unplugged it again. At least if I sell it it won't have a cel for the next owner. So there ya go that's my findings with the egr system.
    TheMainePrius likes this.
  2. Caleb Stoll
    Caleb Stoll New Member
    Warsaw OH
    Are you saying you can run the car with egr unplugged and you don’t get the cel symbol coming on? Could you explain the process in detail?
  3. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    people just ignore it /
  4. Paladain55
    414
    172
    The South
    Yes you get a cel code. I just ignore it. Check my scan Guage on occasion to make sure it's not any other codes. We aren't in limp mode and the car runs smooth still. I think this mod makes the gen 3 prius more reliable like the gen 2 prius.
  5. ChapmanF
    19,022
    It also retards the ignition timing.
  6. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    I don't want a retarded Prius.
    moto g power ?
    Raytheeagle and Mendel Leisk like this.
  7. Paladain55
    414
    172
    The South
    Update: We have hit 200k. I've figured out oil consumption is mostly just tied to RPMs. Oil consumption was not affected by swapping viscosity either. 0w-40 consumed like 0w-20. I found that the car consumes oil above 3000 RPMs usually on long highway trips and its very hill/mountain-ey here. Keeping RPMs below 3000 RPM car consumes a quart of 0w-20 every 6500 miles. EGR is unplugged. Still getting around 54 mpg average for now. So we don't have a bad head gasket but we do have bad piston rings. I replaced the spark plugs back around 120k but I will probably do them again here soon and attempt to do a leak-down test as well. Past that the car still drives very well. Somewhat respectable. Oh and I still have p0401. I haven't noticed any limp mode effects or extra CEL codes.
    GG707 likes this.
  8. Paladain55
    414
    172
    The South
    *above code is p0403 not p0401
  9. ChapmanF
    19,022
    Driving around with the timing constantly retarded is a kind of a "limp mode effect", just maybe not severe enough that you notice it.
  10. rjparker
    rjparker Tu Humilde Sirviente
    11,103
    6,967
    Texas Hill Country
    It would seem this whole discussion is purely academic if the cooler was 100% plugged anyway. Unless the real issue is a leaky egr valve at low rpms which causes a bad idle or misfire and perhaps gets mechanically sealed off by the owner. We know the egr valve should be closed at startup and low engine power.
  11. Paladain55
    414
    172
    The South
    The car does run a different map by the way so you are correct. Its like a fail safe running mode. The biggest difference i see is the amount of load the engine uses at each rpm is different than running with EGR connected.
  12. mattf1a
    mattf1a New Member
    Southern CA
    2014 Prius v wagon
    I have a question about Disabling the EGR valve: If my engine gives me rough shuddering accelerations when starting from a stop, but it runs smooth at driving speed, and if I disable the EGR by unplugging the harness and then the engine runs smoothly in all conditions, does that mean that there is nothing wrong with my head gasket? Forgot to state that I have a 2014 Prius V with 162000 miles and have never had a problem with it until the rough acceleration thing started a couple months ago.
  13. rjparker
    11,103
    6,967
    Texas Hill Country
    A better test is to block the egr tube from the valve to the intake. If the egr is not working or leaking it will allow exhaust into the intake regardless of the electrical. Also aftermarket egr valves are known to stick open.
    Car Care Nut video with egr block tube test
    Rough shuddering is more commonly a leaking head gasket on these engines but blocking the egr can remove egr from the list. Don’t waste your money on plugs, coils or injectors when the issue goes away quickly as you describe.
    #33 rjparker, Aug 3, 2024
  14. mattf1a
    mattf1a New Member
    Southern CA
    2014 Prius v wagon
    Thanks for the reply and the video link. I had watched that before but wasnt sure about running with a spatula in place. So if I block the EGR with a spatula and the problem goes away we can conclude that it is NOT a head gasket?
    One other detail here is that if I open the cap on the coolant reservoir in the morning after it sits all night I have a good puff of pressure blowing out the exit tube..
  15. rjparker
    11,103
    6,967
    Texas Hill Country
    Yes - after a couple of weeks. We have seen people change plugs and the symptoms go away for a short time. Others loosen up the reservoir cap and eliminate symptoms for weeks. Meanwhile an underlying hg gets worse in many cases and that’s not good if it costs an engine.
    A quality dual view borescope when cold with pumped up coolant pressure is the most definitive test from a hg fail standpoint on this engine.
    Car Care Nut HG Borescope at 7:40
    #35 rjparker, Aug 3, 2024
  16. mattf1a
    mattf1a New Member
    Southern CA
    2014 Prius v wagon
    Thank you for adding that video. I have not seen that one before.
  17. Paladain55
    414
    172
    The South
    Never understood the blocking the egr valve. The unplugging of the valve is the same test. And more safe. If you unplug the valve and the rough running goes away it means the head gasket is fine but more specifically it means your egr system needs deep clean. Diesel trucks with EGR systems have the same problems as our priuses with EGR systems hence why everyone hates the new diesel trucks and why they delete them. (it makes them reliable)
    There's a reason why the us government models that run diesel engines come from the factory with egr block off plates.
  18. rjparker
    11,103
    6,967
    Texas Hill Country
    If the egr is sticking open or jammed open you get a stumbling engine.
    When the normally closed egr at low rpm is allowing flow it fouls the air fuel mixture. Blocking is a test for this situation.
    A clogged egr cooler won’t cause stumbling or severe hg shaking.
    #38 rjparker, Aug 6, 2024
    Brian1954 likes this.
  19. Paladain55
    414
    172
    The South
    Clogged egr does cause knock and head gasket issues. Especially cylinder 1 and cylinder 2. It doesn't meter the correct amount of egr to each cylinder. Hence why i just unplug it at this point. I'm still blown away only prius people disagree. Every other car group knows.
  20. ChapmanF
    19,022
    It's pretty well agreed here that clogging at the manifold causes that; there are four separate passages that can get differently clogged, leading to different EGR % in different cylinders, and the car can't detect and protect against it because there is only one MAP sensor.
    Where opinions differ more here is where only upstream clogging, say at the cooler, is involved.
    It Ain't What You Don’t Know That Gets You Into Trouble. It's What You Know for Sure That Just Ain’t So — Quote Investigator®
    Paladain55 likes this.
