Unplug EGR Valve
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Paladain55, Oct 20, 2021.
  1. Vince Weiss
    Vince Weiss New Member
    Marthasville Mo
    I am sorry if you have already updated In other threads, I am new to the group. I have recently purchased a 2010 Prius for very cheap as it was running rough. Me and a friend were messing around with it and found out it runs perfectly fine unplugged and now I found you talking about this. How is your unplug repair holding up after all these years? Thanks!
  2. Paladain55
    Paladain55 Active Member
    414
    172
    The South
    Still going great! Car runs better than when i bought it at 90k. Open air catch can and the egr delete i don't get any start up knocks or rough running. I recommend it to all.
    ozmatt likes this.
  3. ozmatt
    ozmatt Active Member
    637
    263
    Australia
    Very interesting read op, so this is around 4 years running with EGR unplugged? how many miles has it been
    I'm near finished doing a head gasket on my 2012 V and thinking of leaving it disconnected from the get go
    Paladain55 likes this.
  4. Paladain55
    414
    172
    The South
    I think at this point its about 60k miles. So it does work. I've probably had 30-40 people tell me they also did it and it cured their issues as well. Car still gets the same gas mileage it did as when i bought it.
    I would recommend to all to disconnect.
    jerryedwards likes this.
  5. ozmatt
    637
    263
    Australia
    sounds good to me Paladain55 .. I was thinking about the engine light being on all the time with the valve unplugged and how dangerous it really could be, i think the only real situation to look out for would be the electric water pump failing anything else would be pretty obvious, and when the water pump fails a lot of the time people are not getting a code anyway jus the temperature light comes on so it would be obvious anyway.
    I currently have an immaculate clean egr system and manifold, have not driven the car yet as still need to put a few more things back on the engine after head gasket repair and always busy with other stuff, hopefully i get time in the next day or two..
    Decision needs to be made about maintaining a functional clean egr (oil burner 300k km engine with virtually no service history) vs disconnect and never think about it again
  6. Paladain55
    414
    172
    The South
    Yup. Do the piston soak, egr delete, open air non assisted crankcase ventilation system. I converted my car from a knocking oil burner to one that doesn't knock or burn oil.
    Check engine light is always on but i run a scan gauge at all times. I can check if i want. I also agree with the water pump thing. I will continue to run the original until my temp light goes off or i notice my water temp on my scan gauge going up uncontrollably one day. I changed the coolant pretty often with SLLC though. Should help with the pump. The coolant is actually used as a lubricant on these epumps.
    I'll be interested to see how long my car lasts. I've gone pretty hard core on maintaining it.
  7. ozmatt
    637
    263
    Australia
    Hey Paladain :) .. have you capped the manifold and left the pcv end open to atmosphere?
  8. Paladain55
    414
    172
    The South
    i capped off the manifold and intake. The upper and lower crankcase ports going to a catch can with a filter on top.
  9. jerryedwards
    jerryedwards New Member
    virginia
    How do you unplug the EGR? I've tried to find you tube videos but they are all about actually removing the part.
    It's that the case or is it as simple as pulling a power plug somewhere or removing a fuse?
    My car is knocking when I start the car and I'm praying this will fix it.
  10. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    Electrical shutdown - remove the connector from the EGR valve.
    Mechanical shutdown - plug the exhaust gas passage through the EGR cooler, EGR valve, intake manifold.
    But remember that you will have an engine malfunction lamp that will be constantly on the dashboard.
    Brian1954 likes this.
  11. jerryedwards
    virginia
    I found the plug! but when I start the car up in the morning it still shakes for a while.
    Im guessing its a head gasket problem?
  12. rjparker
    rjparker Tu Humilde Sirviente
    11,103
    6,967
    Texas Hill Country
    If the egr is causing it you will get a P0401 specific to flow at the wrong times or no flow at the right times.
    Some continuous rough idles are caused by a sticking open egr valve. Rattles at cold start initially and most engine starts later is most likely a head gasket.
    Repeat for emphasis:
    Test for egr sticking
    Car care Nut Egr video with block tube test
    Head Gasket Test
    Car Care Nut HG Borescope at 660s
  13. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Have you removed the connector from the EGR valve?
  14. jerryedwards
    virginia
    I have, and it worked fine on day one, but I had popped the coolant reservoir lid and I guess doing that removes the rattle on the next cold start.
    Day two the rattle was back and worse
    question though, does the egr use engine coolant? What happens to that after you unplug it? will it cause a leak?
    I did a delivery on a long bumpy driveway so I was going pretty slow, at a point the battery drained and it was trying to charge that while powering the car up that slow driveway.
    On the way back I noticed a line of liquid where I had driven, for like 3 miles. But the odd thing is I didnt notice any low levels, coolant, electric coolant, brake fluid and engine oil all looked good. and gas mileage is normal. Now im wondering if that was pouring out from the egr lines?
  15. Mendel Leisk
    42,346
    That releases pressure on the coolant system, gives the head gasket a brief reprieve. :rolleyes:
    MAX2 likes this.
  16. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    You still haven't answered the question about the EGR valve connector.
    The coolant circulates through the EGR cooler circuit and then into the engine with the radiator.
    The EGR valve does not interact with the coolant; it regulates the flow of some of the exhaust gases into the intake manifold.
  17. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    What about the inverter coolant?
  18. jerryedwards
    virginia
    I unplugged the egr power cord from the egr. but that doesnt seem to be the problem. now im trying to decide to leave it unplugged or plug it back.
    Im hoping head gasket sealant will work, I am loosing a bit of coolant sometimes, but very small amount. I think thats my only option since it has to many miles to replace the head gasket to be worth the money. ive read many people tried it and it let them keep driving the car for another year with out problems. one guy pours in a can every month and replaces the water pump every few months.
    I plan to get another car, but right now theres nothing good available near by and I dont want to keep renting a car until I can find another option.
  19. ASRDogman
    8,066
    4,086
    "Im hoping head gasket sealant will work"
    Well, you might as well trash it now. That crap does not work! It will seal EVERY little passage,
    except the head gasket. The heater core, radiator, thermostat, coolant pump, and every little
    passage in the whole coolant system. A real nightmare to get that crap out of the system.
    Most of the time it means replacement expensive parts.
    There are some who say it works, but I don't believe them. The evidence
    I have seem proves them wrong.
    The ONLY way to properly fix it, is to replace it. And make sure the head is not warped.
  20. bbrages
    bbrages Member
    169
    47
    St. Louis
    Usually liquid dripping under a car is water condensing from the AC evaporator
    ASRDogman likes this.
