Unplugged charger while charging
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by speedypri, Sep 12, 2019.
  1. speedypri
    speedypri New Member
    San Diego
    2013 Prius Plug-in
    Hello Prius world. I have been enjoying my prius plug in for about a year and last night my girl decided to unplug it from the outlet while it was charging. I plugged it back in and no orange charging light. Thought it was done till I noticed the car say charging was interpreted and the ev port had the light on still. I've depleted the ev battery in my commute and tried a level 2 station by my house. Didn't work.
    I read some of the threads on here with similar issues so I will answer the common questions, no it is not on a ev timer. It uses a 220v charger at home. No oem charger. No orange light with home or ev charger station.
    I'll be checking the o rings and handle to ensure it "engages". 1568318876162.jpeg
  2. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    I hope you were not too mean to the girl. A few dollars can fix anything on the car that broke. Maybe a fuse?
    52,849
    try disconnecting the 12v for a few minutes, but i have to warn you, you might lose some data like trip info
  4. 3PriusMike
    3,101
    2,421
    Silicon Valley
    I probably have unplugged while still charging 100 or 200 times and nothing bad happened.
    Well, nothing bad to the car.
    PIP was new in 2012, so I've probably charged it over 2500 times.
    Mike
    jerrymildred and Raytheeagle like this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    I’ve pulled the cord on our 2019 prime that we’ve had since April and nothing bad has happened;).
    It flashes a message in the cabin, but that’s easily dismissible (y).
    jerrymildred and 3PriusMike like this.
  6. speedypri
    San Diego
    2013 Prius Plug-in
    I tried the trick of unplugging the 12V for 3 to 5 minutes. Turned the car onto ready. Turned off. Plugged in. Unplugged. Plugged in. Nada.
    I first tried unplugging 12V, using different chargers
    Is it a fuse I can change?
    Old lady beat herself up more than I did because we both know how much Toyota charges...450 to start any electrical work
    #6 speedypri, Sep 12, 2019
  7. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    Could the charging cord need to be reset?
  8. speedypri
    San Diego
    2013 Prius Plug-in
    Cable charger doesn't have a reset button than I saw but I used the same outlet and charger on my neighbors volt and starting charging the car right away. So that eliminated breaker to the house, cable, outlet.
    Was it unplugged from the outlet while it was charging? I get removing it from the outlet on the car but I know to never unplug from the outlet
    #8 speedypri, Sep 12, 2019
  9. Pluggo
    608
    534
    There is a world of difference between unplugging at the charging port versus at the wall outlet. The push-button on the pistol grip disconnects power before the plug can be removed. But yanking the cord out of the wall during active charging will produce a visible spark accompanied by a voltage spike. It's probably twice as bad with a level 2 charger operating at 220 volts.
  10. speedypri
    San Diego
    2013 Prius Plug-in
  11. Pluggo
    608
    534
    I would try to open the charger and look all around for a blown fuse inside, after unplugging it first!
  12. speedypri
    San Diego
    2013 Prius Plug-in
    I'll try that. Even though regenerative braking is charging the battery I imagine there is more than 1 fuse?
  13. bisco
    52,849
    unplugging from the wall is no different than your power going out while charging. the car can handle it. i think there's a blurb in the o/m
  14. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    If I'm correct in gathering that the wall outlet is still working and that your EVSE worked on your neighbor's volt, and a different charging station did not work for you, then that definitely narrows it down to the car. Even though you don't report any indicator lights, there's still some sort of fault that ought to show up as a code. I think I'd check for trouble codes first using Techstream or another PiP literate reader. It would seem that unplugging from the wall induced some sort of s power spike that the car didn't like. One can get away with that most of the time, but apparently not all the time.
    If it's a blown fuse, I would not expect a code, though, so that's the other place to look. In fact, before you doo anything else, how about fuse #17 in the engine compartment?
  15. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    I've stupidly done this before (while it was actively charging) and can confirm the quite noticeable sparking. In my case, it didn't cause any damage, however, I can see how it would.
    jerrymildred likes this.
  16. 3PriusMike
    3,101
    2,421
    Silicon Valley
    To prevent sparking...press the button on the charger cable, wait ~1 sec, then pull the charger out.
    Mike
    Pluggo and jerrymildred like this.
  17. jerrymildred
    11,517
    14,167
    Tampa, FL
    That would work. But won't happen when it's someone who doesn't know there's a proper sequence for unplugging. It's really a bit scary that some passer-by could casually yank the plug from the wall outlet and possibly damage the car.
  18. jerrymildred
    11,517
    14,167
    Tampa, FL
    I missed this before. Yes, the battery has two sources of power. The MG's in the transaxle feed the battery through the inverter and the EVSE feeds the charger which feeds the battery through the inverter. Two sources going to the same destination, so it's possible for one to have a problem while the other still works.
    Anyway, it's been a few days: what's the word on the fuse or fuses?
    Yea Right likes this.
  19. speedypri
    San Diego
    2013 Prius Plug-in
    I saw this fuse and its fine. I'll check #17 but I'm sure I did already
  20. speedypri
    San Diego
    2013 Prius Plug-in
    #17 is fine....
