Unplugging the 12 V battery
Discussion in 'Gen 3 Prius Technical Discussion' started by Manhal K Alrashdan, Nov 7, 2015.
  1. Manhal K Alrashdan
    Manhal K Alrashdan Junior Member
    81
    16
    jordan
    Some one had advised me that when buying a used prius, I should unplug the positive cable of the 12v battery for about ten minutes so to reset the car memory of the previous owner's driving habits. According to this "expert "this will improve the car's Mpg.
    Is there any truth in this assumption?
    52,863
    nope.
    #2 bisco, Nov 7, 2015
  3. vskid3
    vskid3 Active Member
    773
    228
    Also, when removing battery cables, it's best to remove the negative first. If you accidentally hit your tool to bare metal while on the negative, nothing happens. Do that while on the positive with the negative still attached and you'll have quite the light show.
  4. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    The car will quickly learn your habits, if different than the previous owner. If you disconnect the 12V you may loose some setting you might want, such as reverse beeping "one beep" to "continuous". There is also a slight possibility you may "zap" the electronics if you do it wrong.
    Best to just drive it.
  5. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    shouldn't things like that be permanently stored?
    as far as I remember, when I switched my 12v battery there was none of those settings gone/
    (& no, I'm not going to disconnect my battery now just to see what happens.... ;) :) )
  6. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I have done this several times, it doesn't hurt anything. You will have to reset time and date. It will increase your EV range slightly, say from 12 to 13 maybe. Also if you are having screen problems it will reset various computers and take care of these problems. Yes, it's safer to remove the NEG.
  7. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    As its a digital device a cold reboot periodically is a good idea, and if the prior owner was very light footed, remapping the computers to full ahead takeoffs will add mpg's, the faster you get to cruising speed the better.
  8. fuzzy1
    10,713
    No that I've heard in more than six years on this forum.
    OP does not have a Plug-In version, so this does not apply.
    Even on the Plug-In, I'd think it would reset only the 'historic' mpg figure to the factory default, used to estimate range. The car's actual range should not be changed.
  9. bisco
    52,863
    i've never understood the 'drivers habits' thing. when i press on the go pedal, it goes. same with the brake. what else is there?
  10. Andyprius1
    2,327
    859
    Cool CA
    I have had a Gen 2 and now the PIP and have rebooted both cars several times. No harm and slightly extended range.
  11. Andyprius1
    2,327
    859
    Cool CA
    Me neither , something from coast to coast maybe.
  12. bisco
    52,863
    that's probably it. what if two people drive the car, will it need treatment for bipolar disorder?:cool:
  13. UberXking
    UberXking Junior Member
    16
    San Francisco, CA
    Probably the seller recommended this. Disconnecting the battery will remove the check engine light for a few miles.
  14. Mendel Leisk
    42,355
    Between me 'n the wife, would our car be conflicted? o_O
