Unstable steering
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by srivenkat, Oct 23, 2014.
  1. srivenkat
    srivenkat Active Member
    596
    93
    IL
    Unless you plan to get rid of the problem car soon, you might still find it worthwhile to pay the diagnostic fee (1 hour labor) and ask to have the steering sensors calibrated? Especially if you bought the cars from the same dealer and explain the fact you have been blaming the issue on the tires so far but now have learned about sensors in the steering that may need calibration, they might look at it. My guess is the whole thing may not cost more than a couple of hundred dollars. They will typically want to start with an alignment check and then might follow thru with calibration if you can show you want the steering to feel and behave like your good car as the reference.
  2. srivenkat
    596
    93
    IL
    I also happened to post my question to AA1car.com and Larry kindly responded:
    Your car should NOT be wandering or pulling to one side, especially at slower speeds.
    Your car has electric-assisted steering. There is a torque sensor in the steering column and a steering angle sensor that tell the steering control system which way to add power assist (left or right). I suspect something is misadjusted or defective in this control system (possibly the torque sensor, or the steering angle sensor needs to be reset).
    If your Prius has a LOT of miles on it (over 100,000), your steering wander problem may be due to worn wheel bearings in one or both front wheels, or worn tie rod ends. These parts should be inspected and replaced as needed.
    There is also a technical service bulletin your dealer shoudl refer to for correcting steering pull problems:
    T-TCI-3964
    February 27, 2013
    REPAIR MANUAL SUPPLEMENT: VEHICLE PULLING TO ONE SIDE
    Larry
    AA1Car.com
  3. srivenkat
    596
    93
    IL
    I think Larry meant TSB-3964.
  4. Tande
    Tande Active Member
    556
    339
    Mich.
    Thanks....I'll give it some thought......we do plan to keep the cars for a good while longer...... they have been trouble/free (other than this issue)...... about a 100 mi. round trip to the dealer, & so not the easiest to do R&D with them.....;)
  5. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Use a tape measure and compare both cars toe-in.
