Unsuccessful 12v jump from pack or cables
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by coach4docs, Feb 15, 2015.
  1. coach4docs
    coach4docs Junior Member
    Chicago
    The 12v battery is dead. When I hooked up the charger the lights came on and the horn began making noise. The key fob isn't able to disable the alarm (?). Is there a manual sequence? Thanks
  2. Lino
    Lino Member
    61
    38
    If the battery is dead, how many amps does your charger provide for the system for everything to work, maybe you should disconnect the battery from the car before charging curious to know what you came up with.
  3. Mendel Leisk
    42,293
    What charger are you using, and where/how did you hook up? Hooking up a charger shouldn't be doing these things, maybe misconnection?
  4. coach4docs
    Chicago
    Apologies for posting to the wrong forum. An additional question -- tried a power pack and jumper cables/different vehicle -- unsuccessful. The dash lights, etc., will come on and the start button light is amber.
    Is hooking up the cables directly to the 12v a no-no? Welcome other suggestions. Thanks
    2012 Prius v (lowercase v for the Prius v wagon, not an uppercase). I have tried both a fully charged battery pack and jumper cables hooked to a different vehicle. The dash buttons will light and the power button color is amber. Two questions -
    1. Could the clamps on both the pack and positive cable not have sufficient contact to transfer an adequate charge?
    2. Is there a prohibition against trying to connect the battery pack directly to the existing/dead 12v in the vehicle?
  5. bisco
    52,803
    you might have a short in the old battery, creating resistance. try disconnecting it and hooking the jumper directly to the cables.
    see my answer in your other thread.
  6. jdenenberg
    jdenenberg EE Professor
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    If your existing 12v battery has a serious problem (shorted cells), it will drain the available current from the "jumper" and prevent your Prius from starting up correctly.
    JeffD
  7. Mendel Leisk
    42,293
    There's no problem hooking up jumper cables directly at the battery post. Something is awry tho: every time you supply power all heck breaking loose. I'd suspect this'll continue, even if you dropped a new battery in.
  8. Alexander63
    Alexander63 New Member
    Spain
    2012 Prius+ MPV
    A little bit different but related question: Did anyone ever try Chinese multi-purpose compact devices like "18000mAh (or 16800mAh) 12V 5V 19V Jump Starter Car Emergency Charger Battery Booster Power Bank" for starting Prius v? Or maybe what do you feel about it?
    My car is Prius+ 2012/2013 with Spanish spec, which I think is basically very similar to Prius v save the number of seats and position of some parts.
    #8 Alexander63, Mar 15, 2015
  9. Alexander63
    Spain
    2012 Prius+ MPV
    I think about buying one but it's so small... Will it suffice?
  10. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    It should......IF the marketing claims that it will start a conventional car, a hybrid should be no problem at all.
    I personally think that with a car with an actual 12 V starter motor, the engine had better be in PERFECT running condition and able to start within the first few seconds of cranking. If it doesn't your are still screwed because there is no way that little thing will run the starter very long without going up in smoke itself.
  11. bisco
    52,803
    you can start the car with 8 d cells, so that should be fine.
  12. Mike500
    Mike500 Senior Member
    2,593
    767
    Read the reviews of a similar item sold in the US.
    These have made the bulky old lead acid jump boxes obsolete.
  13. Alexander63
    Spain
    2012 Prius+ MPV
    Thanks! And what about the cable length in the picture? If the positive goes to the red at the far right, negative probably cannot reach to the bolt at the far left due to limited cable length so where (not so far) to connect it? Maybe someone has a scheme or picture and can clearly mark the best point?
  14. Alexander63
    Spain
    2012 Prius+ MPV
    Thanks!
    #14 Alexander63, Mar 16, 2015
  15. Mike500
    2,593
    767
    The cables can be easily lengthened with 10 gauge wire and butt connector crimps.
    I'm thing of prewiring the connector directly to le battery with the connector sticking out. That way, you won't have to fumble with it in an emergency.
    edc415 likes this.
