Unusual problem while going downhill with cruise control
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by royvogel, Feb 19, 2012.
  1. royvogel
    royvogel TanzMan
    Smyrna, GA
    Anyone have any ideas? Twice now, while going downhill hill (steep grade on freeway) my Prius has revved up to over 4,000 RPMs with the cruise control set at approximately 65 mph. The noise of the engine was my tipoff and I immediately had to turn the cruise control off. This just doesn't make sense to me! Seems like this could be a potential problem for those of us utilizing cruise control!!!
  2. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    How "full" does the HV battery look when this happens? If it's at or near full, it's normal. The car will basically put itself in B mode to do compression braking w/the ICE to keep the HV battery from getting overcharged.
    I used to hit this very frequently where I last lived (would go down a fairly long downhill grade on the way home). I've hit this on certain freeway trips in hilly areas too. Cruise control doesn't need to be on for this and I never use it on the former route.
    Since I have a ScanGauge II, I can monitor the ICE RPMs as well as HV battery SoC. It on cue when the HV battery is very close to 80% SoC (represented as "full" on the 2nd Prius' MFD).
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The Gen 3 will work not to gain speed going downhill with the cruise control on. (Gen 2 just goes faster and faster)
    When you choose B mode or when the HV Battery is as charged as the computers want it to be, the car will use engine braking to slow your speed when you brake. This avoids overheating the friction brakes, which would be bad.
    Your Cruise Control had filled the HV battery and was still needing to lower your speed. Isn't it great the car tries to never leave you without brakes?
  4. Zanrok
    Zanrok Casual Prius Lover
    181
    30
    Reno, NV
    yup yup, I was just gonna say the same thing. I notice that when I am going down steep hills and I engage B mode, and the battery is near full or full the engine will make that terribly loud noise like you described. lol
    I would say its engaging B mode while in Cruise.
  5. royvogel
    royvogel TanzMan
    Smyrna, GA
    Well then, my Prius is smarter than me! Thanks to all for your valuable feedback! You guys and this site are awesome!
  6. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    The Gen 2 does the same thing - it may not be as aggressive as the Gen 3 in the use of engine braking.
    kevin
  7. cwerdna
    12,545
    2,125
    SF Bay Area, CA
  8. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    There are a couple areas in which the Prius makes you rethink your previous experience with other cars.
    Auto A/C: This is more than just giving you cold air. The Prius uses a combination of cooling, heating, vent control and fan control to maintain the desired cabin temperature.
    Cruise Control: Better thought of as "speed control." As we've seen here, the Prius does not only keep you at a minimum speed as set, it will make sure you don't race uncontrolled down a steep hill.
  9. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Is there an RPM meter with the 2011 prius? I'm new to it and didn't noticed it.
  10. TonyPSchaefer
    14,816
    2,501
    66
    No there's not. This has been a point of contention for menu Prius owners and one of the main reasons why some have purchased devices that read the CANBUS and display information such as RPM.
  11. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Not a problem, it is just doing what it was designed to do, use the ICE to slow the car when the SOC is high. I have seen mine at 5K RPM coming down steep mountains.
    Red line of the engine is 5200 and it will not exceed that. The car protects itself pretty well and 4K or 5K is absolutely no threat to the engine as long as it is warmed up.
  12. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    Phew! I thought the runaway Prius had returned! :car:
  13. tumbleweed
    4,067
    692
    Eastern Oregon
    :eek: Please not that again!
  14. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    ...my VW minivan does this on hills (RPM speed up), apparently the transmission is downshifting to control speed. Seems unsafe, especially one time happened on an exit ramp.
  15. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Which begs the question: Why were you running CC on an exit ramp?
    Tom
  16. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    ...don't recall exact scenario but hills, and once the downshift gets started sort of seems like you are out of control for a second. Basically I don't use CC anymore on hills for the minivan.
