Unwelcomed Intruder
Discussion in 'Prime Main Forum (2017-2022)' started by huskers, Oct 5, 2019.
  1. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    Found a dead mouse under the car in the garage this morning. Hope he did not get into my wiring. Guess it is that time of the year to put traps out.
    52,792
    i had to get a pest control service. a mouse a day until they showed up. the garage is still vulnerable though.:mad:
  3. El Dobro
    El Dobro A Member
    7,102
    3,282
    Works every time. ;)[​IMG]
    52,792
    it does, but around here, every time is 1 in 10. they don't make enough traps
  5. huskers
    2,548
    2,488
    Nebraska
    I have had luck the last few years with those glue traps. Trick is not touching them yourself when putting them down.
  6. KennyGS
    KennyGS Senior Member
    1,243
    1,046
    Keystone State
    Were there pieces of PVC wire insulation stuck in between its teeth?
    jerrymildred, huskers and bisco like this.
  7. huskers
    2,548
    2,488
    Nebraska
    and a smile on its face.
  8. El Dobro
    El Dobro A Member
    7,102
    3,282
    I live across the road from a big park, so I see the little critters. They used to climb into the VWs, but luckily, they leave the Chevys alone. I buy the traps 20 at a time off of eBay.
    Data Daedalus likes this.
  9. bisco
    52,792
    my pest co uses them to monitor, they're all over the house, inside cardboard boxes
  10. VFerdman
    VFerdman Senior Member
    1,200
    1,218
    Western Massachusetts
    I have these traps (not sure if mine the same brand, but this is the style) and they collect up to a dozen of critters at a time. I literally discard "a bunch" of victims at a time with these. And I don't even bait them (though you could. I wonder if some used Prius wiring would be a good bait...), no need. They love crawling into these things. Try one. They really work once you figure out where the mice like to "walk" and put one in their path. They just love the design of the entry, it attracts them, somehow. Best (read: most effective) mousetrap I have ever used. They get pretty disgusting inside from all the death and excrement, but they do keep my garage kind of mouse-free. I also have two cats that like to spend an occasional night in the garage. They do not seem to catch the mice, but that steel box sure does. Almost daily at some point in the year.
  11. El Dobro
    El Dobro A Member
    7,102
    3,282
    I pulled the cover off the engine of the PiP and found mouse droppings and I also found nut shells in the air cleaner housing. After that time though, I never found ant again.
  12. frodoz737
    frodoz737 Top Wrench
    4,795
    2,560
    33
    Poison works EVERY time.
  13. El Dobro
    El Dobro A Member
    7,102
    3,282
    Why waste it on mice, I save it for the neighbors. ;)
  14. frodoz737
    4,795
    2,560
    33
    :LOL: But they smell worse...and longer.
  15. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    Opened the hood last week and the insulation on the underside of the hood was gone. Replacement part is not available :-(
  16. huskers
    2,548
    2,488
    Nebraska
    I think my mouse must have been an advanced scout. I have not seen or caught another one for several days now.
  17. VFerdman
    1,200
    1,218
    Try salvage yards or (gods forbid!) ebay.
  18. ice9
    ice9 Active Member
    581
    346
    norfolk va
    2018 Prius
    Just completed mouseproofing using a modified ebsmythe approach (see MouseProofing the Prius). I installed a modified version of ebsmythe's rear vent mouse guards and installed a washable cabin filter with mouse guard, instead of ebsmythe's front cowl area mouse guards.
    IMG_0585.JPG IMG_0585.JPG IMG_0591.JPG IMG_0601.JPG IMG_0603.JPG IMG_0604.JPG IMG_0605.JPG IMG_0607.JPG IMG_0608.JPG IMG_0610.JPG
    VFerdman likes this.
  19. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I scatter moth-balls into all the nooks and crannies and the angle between the walls and the floors, and all along the bottom lip of the inside of the up-and-over door! It seems to wok pretty well, and you're right, it's that time of the year! :)
  20. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    I remember one particular October in Ohio when we trapped about 15 of them in a couple days. :eek:
