Up to 33 miles per charge!
Discussion in 'Prime Main Forum (2017-2022)' started by Digloo2, Apr 21, 2018.
  1. Digloo2
    Digloo2 Active Member
    124
    132
    Phoenix, AZ
    When I got my Prius Prime, it started out showing that I had 19 miles on a full charge. I only live 7 miles from work, so a full charge gets me back and forth plus an errand or two, and I rarely have to engage the gas engine. Mostly when that happens is when I have to drive across town to a class that's ~15 miles from home.
    After about 6 weeks, I stopped charging it and ran the gas engine until the fuel indicator was on the last bar. That took about a month. I've been using the battery since. I've got 1300 miles on the car and have yet to put any gas in the tank!
    The coolest part is that over time, the estimated range for the battery has been going up and up, and now it usually shows 32-33 miles. I don't usually run it all the way down, but it seems to be fairly accurate.
    With gas prices jumping up, I'm pretty stoked!
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
  3. xray22
    xray22 Junior Member
    31
    Vanouver, WA
    I was getting 30-33 mi/charge when I bought the car in the summer. During winter (here in Washington) it went down to ~23-24, now it's moving up again. It's obviously temperature related.
  4. robert benoit
    robert benoit Junior Member
    Montrial Qc Canada
    Technology
    benagi and priuscatprimeguy like this.
  5. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    If you can get 5.5 miles per kWh, you get more than 34 miles. My experience is don't drive over 65mph on freeway and don't brake too hard, you can easily reach 33miles per charge.
    HPrimeAdvanced likes this.
  6. Diemaster
    Diemaster Active Member
    296
    263
    so. cal
    6 days from 6 months old. geting about 27-28 per charge. but im in a hilly area too.
  7. Backley
    Backley Junior Member
    Hillsboro, Oregon
