Update: drive Prime like a Tesla
Discussion in 'Prime Main Forum (2017-2022)' started by bwilson4web, Jul 18, 2018.
  1. bwilson4web
    16,414
    I realized today that when the Prime has EV capacity, drive it like a Tesla. Maximize the acceleration to the speed limit; overtake gassers. When the light changes, floor the accelerator and reach the speed limit as quickly as possible.
    What this does is 'shame' the gassers who are left at the light. It shames them in front of the rest of traffic. As for us, we spend half as much per mile. The bulk of our miles are cruising behind a gasser or pickup or truck . . . saving the electrons.
    In traffic, follow the notorious gassers as closely as dynamic cruise control allows. If they foolishly exceed the speed limit . . . fine.
  2. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    Bob Wilson .... Rebel With a Cause :cool:
    bisco, jtv, Bob Comer and 1 other person like this.
  3. Pris2002gen2R
    Pris2002gen2R New Member
    Fresno,California 93619
    2002 Prius
    bwilson4web.I have notice your very helpful with people with problems,I am a newbie and tried to start a conversation about my problem but do not know how please help me get started,also I wold like to send a sample of my trans fluid car has 225,678?miles probably never been change,will tell you more about my problem if you contac me Thanks RICHARD.
  4. Pris2002gen2R
    2002 Prius
    By the way if you drive your Prius like a Tesla,The kids proably love you?
  5. davids45
    davids45 Active Member
    104
    132
    Chatswood, NSW
    2016 Prius c
    G'day Bob,
    I hope you drive with your cabin-air on recirculate!
    Best feature/essential accessory in my Prius-c when stuck in traffic behind a German diesel (a small but nasty amount of emission) or a US-based/designed vehicle of any make (just excessive emissions, particularly those that need multiple exhausts :eek: ).
    When I think more about it, make that any diesel. Their behinds all smell.
    David S.
  6. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    Another Mad Max hiding inside a Prius. :)
  7. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    From the owners manual:
    Observing the following can help suppress battery capacity decline.
    Avoid accelerating and decelerating frequently and suddenly when EV driving.
    Accelerator pedal/brake pedal operation
    ● Drive your vehicle smoothly. Avoid abrupt acceleration and deceleration. Gradual acceleration and deceleration will make more effective use of the electric motor (traction motor) without having to use gasoline engine power.
  8. Sandollars
    Sandollars Prius Maven
    134
    157
    SoCal
    When my Prime grows up, it wants to be a Tesla.... OH WAIT!!!!! I GAVE my Prime to my daughter and BOUGHT a Tesla! :)
  9. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    I'm curious about how this affects mileage. Back in the era of carburetors, there was a pump that squirted extra fuel whenever the gas pedal was depressed. When that pump failed, the car would stall if you pressed the pedal too fast. What this all meant was that stomping on the pedal used more gas to get up to speed than slow acceleration. I don't know if the same effect is present with fuel injection.
    But does it cost any extra energy to use maximum power rather than minimum power to reach a particular speed with an electric motor? Or is this a holdover theory from the age of carburetors?
  10. DavidA
    2,348
    1,823
    Chicago western burbs
    I hereby nominate this post by Bob for the PC Thread of the Year Award.
    I have repeatedly told my wife not to drive the Prime in POWER mode, fearing it become a deadly weapon. Of course, I will use POWER mode myself when she isn't in the car.
  11. bwilson4web
    16,414
    The amount of energy, kWh, needed to reach a given speed is given by the change in kinetic energy:
    • KE = .5 * m * ( v**2 )
      • KE - kinetic energy
      • m - mass
      • v - velocity
    I've deliberately left off the units which are typically metric. But there is enough to point out, the change in kinetic energy is driven only by the change in velocity, not the acceleration. For example, going 0-60 in 2 seconds, 5 seconds, 10 seconds, 15 seconds takes the same amount of energy. It is the rate of energy, the power, that determines the acceleration.
    Energy from the battery, Wh, is given by:
    • Wh = I * V * t
      • Wh - Watt hour
      • I - current
      • V - voltage
      • t - time in hours
    Current dictates the power because the battery output voltage decreases only slightly as the current increases. This is due to the internal battery resistance. So as the current increases, the lost energy is given by:
    • W = (I**2) * R
      • W - Watts
      • I - current
      • R - resistance
    So a maximum acceleration is going to increase the battery energy loss by the square of the current. There is also resistance in the inverter and motor stator windings. The energy loss goes up by the square of the current draw. Double the current and the energy loss goes up by four. So what happens in the car?
    A typical battery-to-motor efficiency is in the 92-95% range. So taking the 95% case for a 75 kW (100 hp):
    • 75 kW = 95% * x
      • x - kW draw from battery, ~79 kW
    • 3.95 kW = 5% * 79 kW
    Now we can double the current and find the power loss increases by a factor of four:
    • 15.8 kW = 4 * 3.95 :: double the current, leads to greater loss
    • 80% = (79 - 15.8) / 79 :: efficiency drops from 95% to 80%
    For maximum efficiency, accelerate and decelerate slowly. For fun, stomp it.
    breakfast, benagi and Raytheeagle like this.
  12. CharlesH
    2,797
    1,165
    Roseville, CA
    And when driving in EV mode, don't even think about "pulse and glide", which applies only to hybrids. All of the power in HV mode is ultimately coming from the ICE, so the idea is to operate the ICE in high power mode ("pulse"), where it is more efficient, and "glide" on the battery with the ICE off. As mentioned by Bob, that does not apply to electric motors.
    breakfast likes this.
  13. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    It's simple, the battery pack could warm up if discharge current is high, which means you press gas paddle to floor.
