update maps?
Discussion in 'Gen 3 Prius Technical Discussion' started by tdubb, Oct 1, 2012.
  1. tdubb
    tdubb New Member
    Is there an update to the exiting dvd maps on the 2010 prius? the map dvd does not include a lot of locations.
  2. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    If there is an update DVD it's in the $200+ price range :mad:
    You'll have to check your map version- then check w/your local "T" dealer for the update disc.
  3. TeacherMan
    TeacherMan Junior Member
    33
    Gahanna, Ohio
    You likely have a Gen 6 Navi with version 8.1 disk. That's what came with my Prius when I bought it in August, 2009. Gen 6 version 12.1 will be out this fall and 11.1 is available now. Toyota has dropped the price to $169, which is still way too much IMHO. I found a Gen 6 11.1 DVD locally on Ebay for $100 so it pays to look around a bit before you plunk down your hard-earned money at the dealership. In my case the 11.1 DVD had a lot of updates and was well worth waiting a few years.
    Tom
