Update on my prius...
Discussion in 'Gen 2 Prius Main Forum' started by BROOK SIDE, Mar 12, 2011.
  1. BROOK SIDE
    BROOK SIDE New Member
    81
    canada
    Online diagnosis is just fine provided we don't work backwards and continue to dwell on something that isn't the problem - but that isn't how it works in this forum apparently.
    I never planned or had any expectation of fixing the problem myself - nor should I. It falls squarely on the shoulders of Toyota to honor their warranty and I will hold them to it.
  2. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Yep. I've even had to put him on my "ignore user" list as he's been spamming me with offensive PM's! Very sad, that's the first time I've had to use the "ignore user" feature.
  3. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    There are times the children around here just need their hands spanked. There is no need to send offensive messages to anyone. People need to learn how to play nicely with others.:mad:
  4. BROOK SIDE
    81
    canada
    does that include repeatedly insisting the 12v battery is defective when members have been told repeatedly it isnt?
    Oh.... also there's this little gems ... first words out of uart's mouth are suggesting I am
    because (again) it's NOT my 12v battery...
    I guess that's how he "plays nicely with others".
    :cheer2:
  5. uart
    uart Senior Member
    4,220
    1,212
    Australia
    ^^^ I simply described your behavior towards me in those terms. The fact that it was an accurate description of your behavior (when I was trying to help you in your previous thread) is completely down to you.
  6. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Time to close this thread also......:cool:
    3 people like this.
  7. uart
    uart Senior Member
    4,220
    1,212
    Australia
  8. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
  9. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    I hope not, I really want to find out what was wrong with the OP's car.
  10. Ryanpl
    780
    158
    Brooklyn, NY
    Don't worry Jeff, good ol' Brook will just start another thread.
  11. BROOK SIDE
    81
    canada
    Me too. :(
  12. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    There are many instances posted on many different cars where the thermostat was stuck open, causing the engine to run cool. That causes the engine to run with an enriched fuel mixture, resulting in poor mileage.
    The quickest way to see if this is the case with your car is to read the OBDII port engine coolant while driving (such as with a Scangauge II). If you live in a cold area such as I do, the engine actually takes a very long time to reach full operating temp, and I have both grills blocked in winter. If you live in warmer areas, such as the west coast, then not so much. I see the coolant running at 60-70C for 20 min. After that it finally warms up to the thermostat opening temp of 85C. Hence, I see poor mileage in winter. Last two tankfuls ran at 7 l/100 km. Current tank is at 6 l/100 km (it's finally warmed up a bit, running around freezing, instead of -20C as it was for the last few months - sigh).
    Hope the guys at the dealership are right about the thermostat, as that's an easy fix.
  13. Patrick Wong
    18,210
    6,516
    Another easy way is to use a handheld IR instant-read thermometer, and aim the laser spot at the radiator hose next to the thermostat housing.
  14. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    What is the price for one of these instant-read thermometers, Patrick? Hal
  15. Patrick Wong
    18,210
    6,516
    They are quite inexpensive. Here is the one that I own:
    http://www.amazon.com/Fluke-62-Mini-Infrared-Thermometer/dp/B000MX5Y9C
    If you have that and a decent digital multimeter, you can take care of a large variety of issues, Prius-related and otherwise. You can see how well your home AC and heater are working, check your refrigerator and freezer temperature, check the body temperature of your significant other/spouse, etc.
  16. BROOK SIDE
    81
    canada
    I could definitely see that happening in Alberta at -20c but not in Vancouver at +5c and upwards. interesting stuff though!
  17. Hal W
    Hal W New Member
    872
    53
    Vancouver has nothing to do with thermostat's sticking! If the thermostat does not stop the flow,it will never reach operating temperature, even in Vancouver! Hal
  18. BROOK SIDE
    81
    canada
    agreed! Just noting that I could see that it would be difficult for a Prius to legitimately reach operating temperature in Alberta in -20c.
  19. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Yes but the Prius doesn't know the actual temperature if the sensor is stuck open...
    You could be on the sun, and if the sensor is broken it would think it was freezing out.
  20. David Beale
    5,963
    1,989
    Edmonton Alberta
    At any rate, what I was alluding to is that a Scangauge can be a good investment. It can be used in just about any car to give the driver more and better information with semi-accurate gauges, and can easily diagnose problems such as the one in this thread. I have two, one in Pearl and one in Bruiser (2007 FJ Cruiser). BTW, both vehicles thermostats work, as verified by the Scangauge readings. ;)
