Updated Coolant Reservior With Radiator Cap
Discussion in 'Gen 4 Prius Technical Discussion' started by ColoradoBoo, Feb 24, 2022.
  1. ColoradoBoo
    ColoradoBoo Senior Member
    1,331
    955
    Monument, Colorado USA
    So my wife's 2017 Prius 2 (LE) doesn't have a radiator cap and I don't like that. My 2021 Prius AWD does and the design is a little different.
    I've asked a Master Toyota Mechanic why they changed it and he didn't know for sure but, like me, is glad they did.
    Has anybody replaced their obsolete parts with the new? I checked prices and they are not bad at all. Does anybody know why they changed it and if it's a good idea to upgrade the old design?
    Here's pics of the old and new
  2. ChapmanF
    18,942
    The "old" one looks exactly like the degas bottle system that came in with Gen 3 in 2010, with the single pressure cap on the bottle, rated for 108 kPa pressure.
    The "new" one looks as if they have reduced the cooling system pressure (the rating on that cap is 88 kPa) and returned to a stagnant-backwater-reservoir system like Gen 1 and Gen 2 for some reason. They must have had a reason, and probably it's explained in the New Car Features manual.
    alanclarkeau likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    You should NOT mess with this as it likely will have an adverse affect on the pressure retained in the cooling loop.......and that is important.
    A really LOT of cars these days have the pressure cap on the "overflow" bottle and not on the actual radiator itself.
    There is nothing wrong with that design.
    Move on and find something else to worry about.
  4. ChapmanF
    18,942
    The change coincided with the manufacturers going from the old overflow-bottle systems to the newer degas-bottle systems, where the bottle fully participates in the coolant circulation and any air gets circulated back to it.
    That 2021 picture looks like Toyota moved back to an overflow-bottle system for that model. I am curious why they did that; as soon as somebody looks it up in the NCF, we'll know, and until then ... we probably won't.
  5. ColoradoBoo
    1,331
    955
    It is curious. While both cars have the same engine (2ZRFXE), the 2017 takes 0W-20 oil while the 2021 takes 0W-16 so I wonder if it has anything to do with that.
    I asked The Car Care Nut on YouTube (he's a master Toyota technician for over 10-years) and he said, "I did ask around and no real answer that makes sense why they switched the newer ones." And he does not recommend replacing the 2017 so I'm okay with that.
  6. Mendel Leisk
    42,242
    I'm really sceptical that's anything more than a policy change.
    Mambo Dave likes this.
  7. ColoradoBoo
    1,331
    955
    Well, in my 2021 owners manual, it says “If 0W16 is not available, 0W20 oil may be used. However, it must be replaced with 0W16 at the next oil change.”
    That "must" suggests to me there is a slight difference in the engines else it would say optional, I would think. I'd rather use 0W-16 in my 2017 because you get better MPGs but I don't.
  8. Mendel Leisk
    42,242
    They could just be doing search-and-replace in the Owner's Manual. In third gen manuals they had exactly the same phrases, only the oil weights editted, thus:
    IHasBirbs and Mambo Dave like this.
  9. bisco
    52,757
    there may be ongoing ring/piston issues they are concerned about
  10. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,558
    2,598
    Taylors, SC
  11. ChapmanF
    18,942
    The 108 kPa cap is still used on the inverter bottle in the Prius through 2022. It was used on the engine degas bottle through 2019.
    The engine bottle for 2020 through 2022 is a reserve tank rather than a degas bottle, and the pressure cap 16401-36030 is used (with a plain plastic cap 16405-37020 used on the bottle itself, pretty much like grandpa's old reserve-tank systems). The spec of 88 kPa on the pressure cap can be read in the OP's second photo.
  12. Georgina Rudkus
    3,558
    2,598
    Taylors, SC
    Correct. 2020-2021 Prius models now use a separate traditional radiator cap.
    Cap - Toyota (16401-36030)
    https://parts.mcgeorgetoyota.com/oem-parts/toyota-cap-1640136030?c=Zz1jb29saW5nLXN5c3RlbSZzPXJhZGlhdG9yLWFuZC1jb21wb25lbnRzJmw9MSZuPVNlYXJjaCBSZXN1bHRzJmE9dG95b3RhJm89cHJpdXMmeT0yMDIxJnQ9bGUmZT0xLThsLWw0LWVsZWN0cmljLWdhcw%3D%3D
    Using the 88 kPa cap would result in lower pressure inadvertant release of coolant, since there is no intervening radiator cap.
    If you use the 88 kPa cap, you'd need the radiator cap replace the radiator with
    Radiator - Toyota (16400-37380)
    #12 Georgina Rudkus, Feb 25, 2022
  13. ChapmanF
    18,942
    So they switched back to an overflow-bottle system, and reduced the spec pressure to 88 kPa.
    They did change the radiator, but it's not where the "radiator cap" attaches; that attaches to the "engine coolant pipe" seen right beside the overflow bottle there.
    If you were doing a retrofit (which I can't think of any reason to do), you'd need the new bottle and "pipe". The old radiator has nipples at the top corners for use with the old degas bottle, which you would need to cap off (or switch to the new radiator). There is still a small upper nipple on the cylinder head water outlet, formerly routed to the top of the degas bottle, which you'd have to reroute to the top nipple of the "pipe" instead.
    Again, I can't think of a reason to do any of that, but it would be interesting to learn Toyota's reasons for changing the design.
    My 2010 is the first degas-bottle car I've ever had, and I have enjoyed how little coolant it ever loses, and how simple it makes the burping process.
    I was surprised to find the degas-bottle patent (I think this might be the original one) was filed by Toyota in 1990. (It refers to some earlier Japanese "unexamined utility model publications", but this might be the first official patent filing.)
  14. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Maybe to meet either emissions or l/100km targets.
    ColoradoBoo likes this.
  15. Prius_10_inside
    Prius_10_inside Junior Member
    LA
    ANYONE KNOW WHAT THIS IS AND IT’S FUNCTION ? A COOLANT VALVE WITH A SENSOR ? IT ON DRIVERS SIDE ENGINE BLOCK…
    I DON’T KNOW WHAT YEAR ENGINE THIS IS — see photo
  16. ChapmanF
    18,942
    It is an electrically-controlled "flow shutting valve" further described in this post and the article linked from it.
    Prius_10_inside likes this.
  17. Prius_10_inside
    LA
    Super … si if direction of exhaust gasses won’t bad enough… someone added direction of coolant flow… (… holding on tight )
