UPDATED! Repaired Prius traction battery ; Warning lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by thomas4782, Aug 7, 2015.
  1. thomas4782
    thomas4782 Junior Member
    16
    Missouri
    Hello PriusChat!
    Background:
    I recently bought a Gen2 Prius with high mileage for a fuel-efficient commute car.
    A bit after buying the car, I received the Red Triangle, Hybrid Warning System, VSC, Brake Warning lights. The car still drove fine. Toyota checked the codes and determined hybrid battery failure. Being out of warrantly, they quoted me $3600.
    Being a DIYer, I removed the traction battery and checked the modules. Most modules sat around 7.43V, but two of them were between 6.5-7V, and a four were only slightly low, ~7.20V. I purchased six modules from ebay to replace the low modules, as well as two HiTEC 4x chargers. I performed the discharge > charge cycling as described in a few threads here on this site, and made sure to wire the modules up in parallel at the end to equalize the voltages.
    The result was that all modules had ~5000 discharge capacity, and a final voltage of 7.82-7.83. I put the traction battery back in the vehicle yesterday (left the seat off until I was certain I wouldn't be pulling anything out), and hooked everything back up. There were no warning lights when I started the car up to test.
    The Issue:
    Today, I test drove it for roughly 12 miles, and the Red Triangle/VSC/Brake/Hybrid Warning appeared as I was braking while exiting the interstate.
    What I have checked:
    12V Battery has 12.62V cold; 12.24 with lights/radio (start 1x with no brake), 12.15 in ready (start 2x with no brake), 13.93 fully started and ready to drive.
    Inverter pump reservoir appears to have pretty good flow, and I can feel vibration when I touch the inlet hose.
    Gas mileage during my short trip was 46mpg, with a mix of city and highway.
    The car appears to drive perfectly fine.
    In which direction should I proceed from here? What else should I check? Thanks for any input!
    GG707 likes this.
    52,819
    welcome! why not get a mini vci to read the codes yourself? you certainly seem like a good mechanic, and you'll need it down the road. all the best!(y)
    GG707 likes this.
  3. thomas4782
    16
    Missouri
    So I took the car to work today, which is a roughly nine mile trip.
    The Master Warning light and the Hybrid Warning light remained lit the entire time, but the Brake/VSC lights did not appear. The drive went smoothly. The battery stayed between 4 and 6 bars for the entire trip, but it is a pretty hilly trip. The battery didn't appear to charge or discharge especially quickly.
    I did perform a 12v battery check using the Maintenance Mode (MFD info button, turn on/off lights 3x), and here are the results I saw:
    12v Maint mode, resting = 12.1 to 12.2v
    12v Maint mode, car in ACC mode = 11.9v
    12v Maint mode, car started = 14.1v
    The guide on this site suggests that a resting voltage of 12.4-12.8v is appropriate, and an ACC mode voltage of >12v. My 12v battery is obviously showing a bit lower than this. Based on this, I will probably purchase a new battery as a precaution.
    Any other leads? What else should I check? Thanks for any input!
    Edit: I would like to note that I also removed all the corrosion on the buss bar copper terminals, and cleaned the battery vent fan before reassembly.
    #3 thomas4782, Aug 8, 2015
  4. Patrick Wong
    18,210
    6,517
    As previously suggested, you need to get Mini VCI so that you can retrieve the DTC. As a DIYer, that is an essential tool for you to have when working on Toyota vehicles.
    It would not hurt to replace the 12V battery or at minimum, fully-charge it. But it is not likely the 12V battery is causing the warning lights to appear.
  5. thomas4782
    16
    Missouri
    Quick update
    I drove the Prius to the store today. NO Hybrid Warning Light, YES VSC/Brake/Master Triangle. Halfway there, the check engine light popped also. On the way back, the Hybrid Warning light DID pop, as well as the Master Triangle/VSC/Brake/CheckEngine.
    I am noticing that all of these lights just come and go pretty randomly. If the problem were the Hybrid system, I would expect the light to always be on. Similarly, if it were the VSC/Brake I would expect all those lights to be on always.
    I am really questioning whether this is a 12v battery issue, I have heard a failing 12v can produce some very wacky error codes.
    I will update again if anything new happens.
  6. bisco
    52,819
    maybe your warning light system is defective. could be that nothing is wrong at all.
  7. thomas4782
    16
    Missouri
    Hehe, perhaps.
    I am going to be placing an order for a Mini-VCI tomorrow morning, hopefully I can get it here this week to diagnose.
  8. kinglew
    kinglew Member
    319
    49
    ny
    2020 Prius Prime
    My guess you have a bad cell in hybrid pack or one of the used cells you replace
  9. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    You could probe the wire frame/assembly that attaches the battery modules together.
    Use a wood dowel to probe the wires and sensors, checking to check for cracks.
    A break in the wire can cause false readings. Even a hairline crack can cause issues.
    If you have techstream you can watch the voltage on the computer and see if it varies/changes while you do the probing.
  10. thomas4782
    16
    Missouri
    Once I get my Mini-VCI in, I will monitor the voltages with it. I don't particularly feel like ripping apart my HV battery again to test the modules, but I will if I must. I have been a bit suspicious about this, as I had a DOA cell in the batch I bought off of ebay; another one of those cells may have been pre-failure. However, the battery has been performing admirably since the discharge>charge cycling.
    Definitely going to get techstream soon. Thanks for the suggestion, if I end up cracking my battery open again I will do this.
  11. gdanner
    gdanner Member
    134
    52
    Central Illinois
    How did you identify the DOA module that came from ebay?
  12. gdanner
    gdanner Member
    134
    52
    Central Illinois
    Random warning indicators leads me to suspect that one or more of the busbar connections on your HV battery pack might be loose or dirty enough to make a poor electrical contact.
    There are photos on Priuschat of overheated busbars and melted orange plastic, as well as black carbon marks from arcing and sparking.
    The peak current through each electrical connection between the threaded stud on the battery module and the busbar is the same as the peak current for the entire HV pack ( +/- 100 Amps for gen2 Prius, more for gen3).
    100 Amps is lot of current!
    When I rebuilt my HV pack I took great care to make sure that all busbar connections and battery module studs were perfectly clean and that all the hardware was properly tightened. The main point of electrical contact between battery module and busbar is on the side of the busbar that faces the battery module, not the side where the fastening nut is located.
    j12piprius likes this.
  13. thomas4782
    16
    Missouri
    When doing the discharge>charge cycling, the module produced a maximum of ~1100 discharge capacity. After 3 cycles, it was still around ~1100. Seems like a module requires >3000mAh to properly function. I measured the voltage, and measured again about a day later. Original voltage was ~7.8, second check was ~6.4v. I have heard they lose a bit of charge after sitting, but certainly not that much.
    I soaked the busbars and the nuts in vinegar and scrubbed with a wire brush to knock any corrosion off. I didn't use a torque wrench to tighten the nuts back, but they were plenty tight. The module studs looked pretty clean, not a lot of corrosion there. I am going to purchase a Mini-VCI and check the codes before I crack the battery pack open. I don't want to do all that work unnecessarily.
    Thanks for the suggestion.
  14. gdanner
    gdanner Member
    134
    52
    Central Illinois
    Confirmed: That module was faulty. Self-discharge of a good module is very slow. I have several spare modules on my workbench that are still well above 7.5V after sitting for months.
    Mini VCI should be a big help as it will tell you exactly what codes are occurring.
    My car has no DTC codes at all for the +6 weeks after my DIY HV pack repair. I'm up to 46 mpg. I'm starting to use EV mode again as I develop more confidence about the condition of my HV pack. I can drive more than 1/2 mile in EV mode at speeds of about 30-35 mph. During these extended EV runs I'm seeing steady HV battery drain of about 20-30 amps, but the SOC display on Prius MFD isn't dropping very fast. The ICE eventually starts up, but this isn't being triggered by a sudden drop in SOC.
    -EB
  15. thomas4782
    16
    Missouri
    Well, starting yesterday I noticed that the ICE was spending more time than normal to charge the HV, even though the HV was at 5-6 bars. I also noticed that during braking, I wasn't getting the normal "99.9mpg", but instead ~65mpg. The same intermittent light issue.
    Today, while traveling I heard the HV battery "tick" while driving and the car popped into limp mode. Turning the car off and on allowed me to drive with battery a bit more, but the ICE was spending 100% of the time charging the battery, which according to the MFD, stopped accepting a charge altogether. It got down to 1 bar and ticked off again, and I got myself home in limp.
    I guess I will pop the battery out again and check the voltages of the cells. I already received 1 bad cell from an ebay seller, I am wondering if more cells from his shipment ended up failing as well. My Mini-VCI is due to arrive sometime in September.
    I am thinking that the lessened mpg while braking is due to built-up resistance in the HV pack. Hopefully, if I can figure out which modules need a replace, I can get it back on the road soon. I bought a couple spares in case of something like this.
  16. thomas4782
    16
    Missouri
    Pulled the battery apart and re-checked the voltages of all the modules. Here's my data. Values are in volts. Modules with a (*) are ones that I just replaced in my recent battery repair.
    1 - 7.73
    2 - 7.75
    3 - 7.73
    4 - 7.77
    5 - 7.74
    6 - 7.74
    7 - 7.74
    8 - 7.72
    9 - 7.78 (*)
    10 - 7.75
    11 - 7.77
    12 - 7.72
    13 - 7.78
    14 - 7.75
    15 - 7.79-7.80 (*)
    16 - 7.77
    17 - 7.73
    18 - 7.76
    19 - 7.70
    20 - 7.78 (*)
    21 - 7.74
    22 - 7.78 (*)
    23 - 7.74
    24 - 7.81 (*)
    25 - 7.77-7.78 (*)
    26 - 7.75
    27 - 7.79
    28 - 7.75
    Module 19 looks possibly suspect. I will probably run a single discharge>charge cycle through each cell, hopefully that will show if one of the modules has suddenly lost the ability to charge/discharge.
    I have a Mini-VCI arriving sometime in September, that will allow me to get some better diagnostics
  17. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    Do a load test.
    Static voltage, while interesting, does not tell the whole story.
    strawbrad likes this.
  18. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    You could take it to a place like Autozone that will read your codes for free. You need this done asap.
    If you DC your positive terminal connector on 12v batt and reconnect it will reset your car then you can see if the codes reappear.
    I got a bluetooth obd2 reader for around $25 which I'm very happy with. You can see in real-time what the battery is actually doing since the battery display bars you see on the dash seems to have a delay and isn't all that accurate.
    It may be that the original red triangle bad battery was never replaced and still faulty. One of the check engine codes will show you exactly which cell block is bad which throws the code when its around 1.2v difference from other batt blocks.
    I'm from MO also and got my car this year from Toyota dealership. The car had 1 previous owner and dealer assures me that car was well taken care of and they looked the car over from top to bottom. Well just couple days after i took car home I noticed that the running brake taillight and front small light was out, then couple months later battery failure. So dealership passes car through the safety inspection yet i got 2 different lights out was pretty fishy. Guess can't trust anyone these days.
    My symptom i had just before battery failure was when i started car for first time that day, the battery bars be like 3 or 4 bars, quickly drop to 1 bar or less, then back in all green in less than 5 min and be normal rest of day. This went on from several weeks before the failure.
  19. thomas4782
    16
    Missouri
    Best way to load test the modules? Car headlight with some wires soldered on, with alligator clips at the end?
    I was under the impression that Autozone wouldn't have the appropriate "Prius-aware" code readers. I have an Advanced Auto pretty close to my house, I might try to hoof it down there, if indeed they would have something to read my codes.
  20. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    They can read the error code #'s, but won't be able to give the Prius specific error descriptions but you can look those up online.
    I'm not sure best way to load test those modules though that may be causing u the error.
