upgrade base radio to support rear camera - radio options
Discussion in 'Prius c Audio and Electronics' started by mintprius, Oct 14, 2020.
  1. mintprius
    mintprius Junior Member
    28
    earth
    Hey so i did a bit of research now. I want to upgrade the stock 518c1 radio in my prius. Its the monochrome LCD. Goal is primarily for a backup camera, but satnav cant hurt to have.
    There appear to be three options that are from other prius C models (I am omitting the ones like camry, regular prius, highlander, etc that may or may not fit. Trying to stay as model correct as possible)
    First off, the connections that are in my car are most likely this:
    The possible radios to purchase are:
    100023 - As you can see by the rear shot, it has a GPS module at the bottom and associated antenna ports. I learned this from research.
    100505 - NO gps module apparent. Fronts nearly identical.
    Question, does the 100505 model have GPS nav? all the ebay pics are missing the satnav module on this 100505. i looked at at least 6 of them.
    Surely someone out there has a 100505 in their car and can provide the answer here.
    The other question is that the 100505 does not appear to have the backup cam connector, which i believe to be the most upper left connector on the 100023 rear picture. But please correct me if i am wrong. Does the 100505 then not support a backup cam? or did they switch it to the rearview mirror like lexus does on later model C's? and whats with those two connectors that i thought were for the GPS? between the USB and speakers.
    100872 - 2018+ Prius c radio. Has a stanav module by the looks of it, but some of the connectors are weird looking now.
    Does anyone have a labelled picture with ALL the connections labelled? Im sure that will make the most sense. I saw one on some forums somewhere but neglected to save it :(
    EDIT: found one that is the video connector, g79. but only one radio above looks to have it, the 100023....
    #1 mintprius, Oct 14, 2020
    RobAustin likes this.
  2. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    Might help if you post your location- USA models are wired differently from rest-of-world models.
  3. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Crutchfield in the USA will custom make a harness for cheap (IMO) to connect any aftermarket radio to the C so that it's truly plug-n-play and depending on what you get you will gain TONS of features over most OEM units (apple carplay/android auto being one of the biggest for many folks). You may need extra hardware to make the steering wheel controls work with it but those can be plug-n-play too sometimes.
    OEM screens are typically very low resolution so any "HD" camera or higher is above spec. I'm using and liking this one which comes with a mounting kit: https://www.crutchfield.com/p_707VT601HD/Boyo-VTK601HD.html. If you live in a corrosive or wet or otherwise harsh environment, I would suggest sourcing stainless steel hardware to mount.
    GOOD LUCK!
  4. mintprius
    28
    earth
    i think you are correct leadfoot. I was able to see my friends prius C which is a 2016. In canada, it has the model number on the face, 100628.
    So there are seemingly more and more model numbers the more i look! I guess i should just pick one, take the plunge and try it.
    Regarding aftermarket, the main thing with that is i am trying to keep it stock as possible. I want tactile controls, not a big tablet like i see a lot of newer head units being. Plus i dont have to do any hacks and it will look correct in the car.
    I'd be opting for a stock 5v camera as well so i dont have to screw with taking power from a reverse light or something.. Too bad all the wrecking yards around me closed down.. its a real shame.
    i will keep the thread updated if i do decide to get one and it works out.
  5. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    We didn't want to stray too far in terms of the static look either. We settled on a Sony with (a few) physical buttons and a rotary encoder volume knob.
    Everything is a compromise. I wish it had more/better/bigger tactile controls, but it covers the basics, with the benefit that it gives us the full carplay/android enchilada and... it's a Sony. Tested, supported, just works, warranty just in case. They can't just fluff it and ship it like the ones included by carmakers.
  6. Danny13pruisc3
    173
    27
    maryland
    there is a wire within the regular harness that provides the video feed. pink?
    I ended up buying a dash cam that has a reverse camera feature.
