Upgrade the side mirrors?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Dngrsone, Apr 23, 2020.
  1. Dngrsone
    Dngrsone Underwhelmed, to say the least
    189
    Lost in a desert somewhere...
    I have a 2016 Prius 2, and I'm thinking about upgrading the side-mirrors for blind-spot detection, et al.
    Will those mirrors plug right in, or what other pieces will I need to get them working?
    Rggaebssplyr and amos like this.
  2. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    It's more than just the mirrors though, and the blind spot warning indicator.
    There's radar sensors in the rear sides of the bumpers that detect a vehicle's presence - I assume these are not the ultrasonic sensors, as they work for a much further distance. There is software to adjust the settings of the BSM in the car settings (so you'd need a firmware update of some kind for the car's ECU), there's also the wiring between the mirrors and sensors to the ECU (I doubt any of it is present).
    alanclarkeau and Dngrsone like this.
  3. Dngrsone
    189
    Thanks. I figured it was a long-shot... maybe I'll luck out and find a 4th gen mostly intact at a wrecking yard that I could strip.
    Rggaebssplyr likes this.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    What country are you in? There are different specifications, depending on which one.
  5. alanclarkeau
    7,045
    7,592
    The USA diagram shows:
    Whether the ECU is the same, or the wiring bus - it seems like they could be some different ones, depending on whether it's Li-ION or NiMH. It also looks like there is a specific bus for models with Blind Spot Monitoring, or Clearance Sonar or TSS.
    It might be easier to change cars.
  6. Dngrsone
    189
    Thanks, I'm in the US
    Well, it was a thought. Got a really good deal on this model 2 used, and don't plan on trading it in until I wear it out... which won't take long: my work commute will have me doing close to 20k miles a years.
