Upgraded Audio Unit Stopped allowing me to select HD stations
Discussion in 'Prius v Audio and Electronics' started by gromittoo, Feb 23, 2020.
  1. gromittoo
    gromittoo Active Member
    718
    286
    philadelphia
    2013 Prius v wagon
    Several years ago, I upgraded my Head unit in my 2013 Prius V level 2. The stock unit was 57010, and I found a reasonably priced 57011 (from a prius V level 3) I managed to get it all to work, except the XM radio, which I did not want.
    I drive for Uber and Lyft, and the main reason I did the upgrade was to get a reliable GPS that works in between the skyscrapers in Philadelphia. Cell phone based GPS signals just don't work in Center City Philly; your position suddenly jumps through a building, and into the alley behind that building.
    For the first year or so, I had HD radio. I found the selection of sub-channels really nice to have (and often commercial free). One day last summer, I stopped being able to select subchannels. For example I can only select 88.5 FM, when I used be be able to select 88.5-1; 88.5-2; 88.5-3; ETC...
    1) At first I thought I hit some obscure menu option to turn off HD radio. I can't find any such option.
    2) Then I had the scary thought that maybe the radio looked at my VIN number, and realized that the car is only a trim level 2, and decided to disable HD radio (but the GPS still works).
    3) My final thought was that something about how HD-FM works changed, and My unit is no longer compatible.
    Does anyone have any Idea how to get the sub-channels back?
  2. gromittoo
    718
    286
    philadelphia
    2013 Prius v wagon
    Problem Solved:
    There is an obscure menu in setup on the 57011 that allows you to disable the HD radio. I think I may have disabled the HD radio right before the pandemic, because HD kept cutting in and out (then forgot I did it). The the Pandemic hit, and I stopped driving for Uber for 13 months. Now that I am Ubering again, I wanted it back.
    I found the option, and re-enabled HD, and I am trying to decide what to do. If I am in a strong signal area, I want the HD. If I get a long ride to a weak signal area, I want it off. I have to stop the car and go through a lot of menus to get to it. It should be easier to enable to disable the HD.
