Upgrading rear brakes - ditch the drums!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by maestro8, Apr 18, 2012.
  1. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,517
    38
    Santa Fe, NM
    I suggest to anyone contemplating this to do their own homework. Download the service manual in order to understand exactly how the system works. It is one of the most complicated braking systems that you can have in a car. It has all the potential for a rathole nightmare. See below for a couple of basic system diagrams.
    It would be far easier and cheaper to put an electric brake axle in your trailer.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,077
    Northern Michigan
    Okay, now the OP's request makes sense. The brakes in a Prius are designed for just the Prius, and that is reasonable since the Prius is not rated for towing.
    As Seilerts points out, the Prius braking system is complex in the extreme. Trailer brakes make much more sense. They are easier to install and will provide more control.
    Tom
  3. Jumpedinthepriasus
    Jumpedinthepriasus Junior Member
    46
    Ct
    Enter maintnence mode, keeps the engine running, when coming to a stop use B mode to keep it on for faster take off, switch back to D any time between 0-50(ish)mph
