Upgrading stock Radio Unit with an Alpine Unit
Discussion in 'Gen 2 Prius Audio and Electronics' started by Miguel Olivares, Oct 9, 2016.
  1. Miguel Olivares
    Miguel Olivares Junior Member
    56
    Oakland
    I just purchased an alpine car stereo and am considering installing it on my 2005 base unit prius.
    Question 1) will I be able to use the steering wheel buttons to control and change the music?
    2) will anything else be messed up if I replace the stereo? ( temperature buttons not working..)
    3) if so, what can I do so in the end, I have an alpine stereo in my base unit prius with all of the steering buttons working?
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    746
    Delaware
    since you have a base model, all you really need is a metra axxess interface for the steering wheel buttons and an adapter harness from scosche which has a 68 ohm resistor made into it. I would contact crutchfield for the correct parts.
  3. Tomek310
    Tomek310 Junior Member
    89
    Riverside
    Spoke with Crutchfield and it seems you'd need about $150, not counting the radio.
  4. 69shovlhed
    2,170
    746
    Delaware
    that seems a bit steep. you might try ebay or amazon for a better deal.
  5. Tomek310
    89
    Riverside
    I bought the PAC TATO and PAC SW interface for $20 off ebay. What do you think about these? What trim kit do I need?
  6. 69shovlhed
    2,170
    746
    Delaware
    the one I got was scosche kit from ebay. it had the bezel and adapter harness w/ 68 ohm resistor installed.
  7. Tomek310
    89
    Riverside
    What is the resistor needed for? And how do you install it?
  8. Rocket Man
    Rocket Man Junior Member
    37
    Denver
    The resistor is needed to terminate a data bus. Since its included as part of the adapter harness, you won't need to do anything additional for everything to work correctly.
  9. Tomek310
    89
    Riverside
    You mean it's included in the PAC TATO?
  10. 69shovlhed
    2,170
    746
    Delaware
    the 68 ohm resistor probably isn't included with the tato, you need to check the instructions to see if it is. if it ain't, do a forum search to find out how to install it yourself, or buy the scosche adapter harness from ebay.
