Upgrading the audio system and vehicle performance
Discussion in 'Prius c Audio and Electronics' started by grizdogg, Sep 9, 2013.
  1. grizdogg
    grizdogg Junior Member
    29
    I am looking into upgrading the OEM system in the car. The first thing I would like to do is add an amplifier and subwoofer. I already have a Rockford Fosgate 8" sub with a 200 Watt RMS amp. I am interested in what vehicle performance impact this has on the C. Will I see a drop in MPG? If so, how big?
    The next step would be a new head unit. I am interested in the Parrot Asteroid Smart because I like the idea of an Android head unit. But other suggestions would be appreciated. And then I would follow-up that upgrade with new components all the way around.
  2. krneidigh
    krneidigh Junior Member
    70
    17
    Pensacola
    I have a stock headunit on C3, navigation, added some polk 6.5 and a Boss BASS600 amplified sub 300rms. Sounds fantastic and no loss in mpg.
  3. B2FiNiTY
    B2FiNiTY Active Member
    979
    226
    The MPG affect will be negligible.
  4. grizdogg
    29
    Thanks for the quick responses. I should have mentioned, I have a C2. Glad to hear the losses are negligible. I have been averaging about 53 MPG thus far and I drive about 130 miles a day, 50/50 split between city and highway. I need a better system considering the amount I am in the car.
    SPH-L720 ? 4
  5. Lasareath
    Lasareath New Member
    Central NJ
    2013 Nissan LEAF
    I'm adding a new system to my Wife's Prius C in the next couple of weeks.
    PriusC-illa likes this.
  6. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    looking foward to the install. what speakers are you upgrading too, if you are? and are you running an amp?
  7. Lasareath
    Central NJ
    2013 Nissan LEAF
    Please see below, sorry for multiple posts.
  8. Lasareath
    Central NJ
    2013 Nissan LEAF
    Leaving the stock HU
    AudioControl LC2i - Used to create pre-outs and turn-on lead for the aftermarket amp.
    Polk Audio MM6501's up front.
    Polk Audio MM650's in the rear.
    Dynamat extreme on all the doors and trunk
    JL Audio XD700/5 - 75W by 4 & 300W for the Sub
    JL Audio CP108LG-W3v3: Single 8W3v3 MicroSub, Ported.
    JL Audio HD-RLC to control the bass
    Speaker, Power and Ground wires are Knu Konceptz
    Fuse Holder, Distribution Block are also Knu Konceptz
    All existing functions of the Stock HU will still work.
    I installed a very similar system in my 2013 Nissan LEAF except mine is 100W by 4 and 600W for the sub. You can see my install pics here
    I will take pics of each step of my Wife's Prius C and post them for reference.
    Lasareath
    (well this post had links and videos of each device but since this is my first post on this forum I am not allowed to post them, so maybe I'll post them in the future)
  9. kingnba6
    1,018
    242
    NY
    thanks for the updated list. giving me some ideas.
    Lasareath likes this.
  10. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    wrong thread...
  11. Lasareath
    Central NJ
    2013 Nissan LEAF
    I received all the gear I need, Speakers, Sub, Wires, Amp, LC2i, everything, Just trying to figure out which couple of days I can do the install. When I did mine in my LEAF it took 25 hours. 12 hours one day, 13 the next so I'm pretty sure this will take just as long.
    I need to find links on removing door panels and running a power line to the 12V battery. On my car there was an unused 1/2" grommet through the firewall that I was able to run my 4 Gauge power line through. The only hard part is that it was behind the glovebox.
    Are there any unused holes through the Firewall on the C?
    Thanks,
    Lasareath
  12. kingnba6
    1,018
    242
    NY
    the C has the battery under the rear seats, so no need to drill in the firewall
    los panda likes this.
  13. los panda
    los panda Member
    155
    23
    one of my favorite "features" of the car.
    mounting the amp under the front passenger seat; the power and ground wires are about 3 ft long, each.
