Upgrading to Dual Head Charger? Check Out ClipperCreek Trade-UP! Program
Discussion in 'Prime Plug-in Charging' started by Tideland Prius, Oct 23, 2020.
  1. Tideland Prius
    16,073
    If you have a high power ClipperCreek and want to upgrade, there's an offer.
    Double your charging capacity at your home or business with the ClipperCreek HCS Dual Charging Station. The HCS-D40 is equipped to charge two vehicles simultaneously with just one station. Plus, if you already own a ClipperCreek HCS-40, HCS-40P, HCS-40R, HCS-40PR, HCS-50, or HCS-50P, you can replace it with an HCS-D40, HCS-D40R, HCS-D40P, HCS-D50, or HCS-D50P and receive $250 back from ClipperCreek! The new HCS-D mounts to the same bolt pattern and utilizes the same service, making the upgrade both easy and affordable. Click Here to see a short swap-out video!
    For a limited time only, ClipperCreek is offering to buy back functioning HCS-40, HCS-40P, HCS-40R, HCS-40PR, HCS-50, or HCS-50P charging stations for $250 when you Trade-UP! to an HCS-D40, HCS-D40P, HCS-D40R, HCS-D50, or HCS-D50P. Call a ClipperCreek Product Specialist today to place your order!
    Accepted Models for Trade-UP!
    We are currently accepting the following models for buy-backs of $250 with the purchase of an HCS-D40, HCS-D40R, HCS-D40P, HCS-D50, or HCS-D50P:
    Trade-UP! Program from ClipperCreek | EVSE Trade In | ClipperCreek
    fotomoto and mr88cet like this.
  2. mr88cet
    mr88cet Senior Member
    2,306
    1,331
    Austin, TX
    Good info, thanks.
    We have an LCS-30, so I guess this doesn’t apply to us. Oh well...
    There is a chance that we could trade our old Gen-2 Prius on a full BEV, in which case we’ll have two cars to charge. Then again, (before COVID19) I drove 40-45 miles which, between our LCS-30 at home and chargers at work, we can I charge that just fine. Meanwhile, my wife drives very few miles per day — in fact most days doesn’t drive at all. The chances well need to charge both at the same time are actually pretty low.
  3. fotomoto
    fotomoto Senior Member
    5,597
    3,771
    So. Texas
    My CC unit is about 6 years old now with rock solid operation. (y)
    Tideland Prius likes this.
  4. Tideland Prius
    16,073
    I noticed it is cheaper to buy two separate units than this single dual-head charger but I guess this assumes you already have two outlets available.
    mr88cet likes this.
  5. iplug
    iplug Senior Member
    2,450
    1,698
    Rocklin, CA
    Might fit a certain niche if easily accessible to both vehicles and neither needs full available power simultaneously.
    In our case we have two HCS-40P NEMA 14-50P units on opposite sides of the garage. Garage cabinetry towards the front leaves no room for a unit like the HCS-D40.
    It does cost 2x+ two separate similarly powered units, although that's one fewer line to run conduit and other electrician expenses. However, the other issue is that it is max 7.7kW of power at 32A x 240V, like each HCS-40P. This is not a problem for the Prime, but most other PHEVs/BEVs can take at/near full power such as our Leaf and M3. Current Prime owners might want to "future-proof" by having max power available to both vehicles they may own years down the road.
    Happy with our trouble free ClipperCreek units, the oldest 8 years.
  6. mr88cet
    2,306
    1,331
    Austin, TX
    And outlets of sufficient capacity. We got the LCS-30 because it was the only 24A (meaning 30A breaker, code requiring a 20% buffer) model we could find. If we were to go up to a dual charger, we’d have to beef up our breaker box.
  7. Salamander_King
    Salamander_King Senior Member
    10,964
    8,840
    New England
    Just purchased EnelX JuiceBox. But I will not be needing two chargers for a while unless we decide to trade-in our Pathfinder Hybrid to something with as large of cargo and plug-in. Currently, Pacifica PHEV is the only car that fits the bill.
  8. Tideland Prius
    16,073
    Hmm, the way I understand it, is that the dual charger uses the same amperage as your outlet, it just divvies it up between the two heads (kinda like a public charger).
    So basically you can split the power between your two cars and will adjust the split on the fly (e.g. as one reaches full and starts stepping down, it’ll shift more power to the other car).
