Upgrading to keyless entry and push button start for less $
Discussion in 'Prius c Accessories and Modifications' started by Usernameinuse, Sep 30, 2012.
  1. Usernameinuse
    Usernameinuse Junior Member
    30
    IT WORKS, pretty awesome. I paid south of 400$ for the install but the installer (who is a pretty nice guy) said he would have charged $400 if he knew there were no wire schematics available to him. It works flawlessly and is really cool, looks completely stock.
    There are 2 ways you can have it done, 1 by keeping the key ignition intact and breaking off the valet key or a copy without a chip in the ignition or by taking the whole key ignition cylinder out (that is what I chose although I think I would have liked to keep it in in case of a problem). I will take some pics and video tomorrow. Hope this helps some people. Wasn't as cheap as I initially thought but I am happy I did it.
    52,862
    that's great news, well done, all the best!
  3. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    Thanks. I am anxious to see your video.
    Dan
  4. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Good, will added as part of my list.
  5. Usernameinuse
    30
    Here is a quick video I shot. Sorry about not being all that technical with the terminology.
    Dylan Doxey and ftl like this.
  6. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Great Great. The only cons is the key hole cover. But else like it.
    What about autolock how it work really?
  7. Usernameinuse
    30
    yeah keyhole cover could look nicer but it is what it is, not really that huge a deal. The autolock( and unlock) works perfectly, no wait at all when you arrive at the drivers side. If you need all 4 doors to unlock you have to press the button or set it up when it is installed so that all 4 unlock when you approach.
  8. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    So it's programable for all doors also, now get some $$$ to ordering. What about wiring? It was easy? Plug n play?
  9. Usernameinuse
    30
    I'm not 100% sure on the 4 doors part, you would have to call tech support, their number is not on the site but my installer got it through the install guide that comes with the setup. I will post it later when I get the box out of my car. As for easy, as previously mentioned, the experienced installer I used said it would have been a lot easier with the wiring schematics. This is the first Prius C installed with an aftermarket pushbutton/smartentry that he knew of and in all my research so perhaps if it gets more common it will become easier to get info/get it for cheaper.
  10. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Thanks man.
  11. WD0AFQ
    619
    152
    Dexter, Mo.
    Thanks. I am not a fan of pulling out that ignition though. I have not seen a 3 or 4 with this option so don't know what the steering column looks like on those.
    The thing looks like it works as designed, pretty slick. Sounds like a 800 dollar accessory with install.
    I appreciate your time with the video.
    Dan
  12. shuiwm
    shuiwm Junior Member
    New York, NY
    it look like a good mod, but for $800 I rather go for the pc3, for addition $900's it got Nav (I agree the smartphone Nav may be better) & other goodies but most importantly, it not void any warranty, but if you can install it you self to save that cost that's another story.
  13. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Does anyone else installed this????
  14. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    to the OP. i see you are in NY, where did you get it installed from? im in queens.
    but i love the keyless entry and start. makes life so much easier now! but i always hated the fact of losing the security of the steering lock
  15. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    This is something I haven't checked. Do the C 3/4 not get the security lock?
  16. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Checked it last night. Confirmed... we DO get the security lock.
  17. kingnba6
    1,018
    242
    NY
    thanks for checking that out. i never knew that.
  18. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Just to let you know guys I receive an email from Welcome to Advanced Keys concerning if the OEM start button is compatible with their system and YES is compatible.
    So anyone have the electrical wiring to the ignition and all stuff required to this to work?
  19. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Anyone else do this mod????
  20. Farfle
    Farfle Member
    69
    44
    Yes we definately need some more guinea pigs for this mod! At least we know it SHOULD work and have video proof of it, but it would be nice to have someone create a step-by-step guide for DiYers.
    Also, I'm confused, the OP said there's two ways of going about installing this: leaving a copied physical key (just the metal stock of the key, w/o the chip) in the key ignitiion and leaving the key ignition installed, or removing the key ignition altogether. It seems the first option would be the MUCH more preferred solution, so i'm confused why the OP decided to go with opt #2 and tear the whole stock out? Then also, does doing this then remove the security lock feature because a.) in the case of opt #1 the physical key would be permanently left in the ignition stock; or b.) there is no ignition stock for the security lock.
    Thanks
