Upscale Prii an endangered species ?
Discussion in 'Gen 3 Prius Main Forum' started by revhigh, Dec 5, 2013.
  1. bisco
    52,822
    mm-hmm.
  2. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    Fuel tanks are specified by the amount of volume they can hold. Consumers would have a difficult time converting a weight of fuel to knowing how full their fuel tank is.
    Consumers are used to calculating fuel economy by using MPG or L/100km, both of which require volume to calculate, and neither requires weight.
    The entire fueling infrastructure is configured to meter fuel by volume, not weight. Retrofit would take a considerable expense and retraining of the population of drivers and station attendants.
    Assessing value could become confusing when fuel densities change seasonally, or vary by formulation. For example, winter blends of #1 and #2 fuels would confuse customers when suddenly their fuel tank capacity holds a different weight of fuel. Another example would be blends of ethanol confounding the consumer. Only mathematicians would be able to figure out how far the weight of fuel they purchased will get them, or how much it will cost.
    Lets continue your BTU / lb list...
    Gasoline: 114,000 BTUs per gallon, 6.073 lbs / gallon -> 18,771 BTUs / lb.
    Diesel: 128,700 per gallon, 6.943 lbs / gallon -> 18,536 BTUs / lb.
    Ethanol: 67,100 BTU per gallon, 6.584 lbs / gallon -> 10,191 BTU / lb.
    With ethanol containing roughly half the BTU per pound compared to gasoline, various blends of ethanol will result in varying weights of fuel being carried by the fuel tank, and a wildly varying mileage per pound of fuel.
    BTU / lb does not help the consumer figure out what the most efficient, economical way to travel is.
    What was your intent of portraying diesel and gasoline as nearly equivalent fuels if not to dissuade people from choosing diesel technology? If I was mistaken and you are not against diesel as a transportation fuel, then I apologize for arguing against a point you were not making.
    I consider myself fuel agnostic, so the preciousness of diesel is only related to how economically I can accomplish my transportation needs.
  3. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    Diesels are inherently clean for emissions of volatile organics (hydrocarbons) and carbon monoxide. On the other hand, diesels historically have had high emissions of nitrogen oxide and, of course, particulate matter. My understanding is that the latter two problems have been solved thanks to particulate traps. A few years ago, a new diesel vehicle was brought up to Capitol Hill in Washington. The engine was started, and someone held a white handkerchief to the exhaust. The handkerchief stayed white.
  4. BrianPB
    BrianPB Member
    114
    36
    Sylmar, CA
    The 17" wheels on the five yield lower fuel economy than the 15" wheels. It's harder to get over 50 mpg especially since mine didn't come with low rolling resistance tires. I think they would be pretty close. I would like to get behind the wheel of the accord hybrid and see what the real world economy is. I would also like to drive my prius with 15" wheels on to see the difference in economy.
  5. bisco
    52,822
    i would too. the hyacc must have 17" wheels?
  6. BrianPB
    BrianPB Member
    114
    36
    Sylmar, CA
    Yeah the Accord Hybrid has 17" wheels with michelin energy saver tires I think.
  7. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    You have absolutely no idea that the above is true, you're just saying it because you're biased toward the Prius. Both road test reports I've seen clearly say that it's easy to achieve the EPA numbers.
    REV
  8. bisco
    52,822
    i suppose it comes down to weight and aerodynamics.
  9. bisco
    52,822
    i'm not saying it can't achieve it's numbers, we get 50 in the hyacc. we get 65 in the prius.
  10. revhigh
    986
    141
    The Accord we're talking about isn't a plug-in like yours.
    The Accord is a far better car than the Prius ... In virtually all areas ... Unless you absolutely REQUIRE a hatchback .... Otherwise there's no comparison.
    I got into my Prius for $21k brand new, that's why I mentioned UPSCALE Prii as the intended target. I wouldn't have paid $9k difference at the time, but if it was a $5k difference ... Or even money .... It would be a much tougher decision.
    REV
  11. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    we didn't get that nonsense here. (Australia). I've no idea what mine is. You could specify which options/extras you wanted according to your budget. Mine was a "demo" model (actually the boss's wife had commandeered it and he asked sales to get rid of it while they were on holiday in Vietnam.) with 5000 kms so I didn't get to specify anything but did get $12,000 dollars off and still got a new car warranty. :) It doesn't have a moon roof or the fancy parking and super cruise control (normal CC) which I am very grateful for.
  12. southjerseycraig
    438
    107
    Cherry Hill, NJ
    Is a hybrid Camry a reasonable alternative to the Accord hybrid?
  13. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Yes, similar in size but the EPA rates the Accord better in MPG.
  14. revhigh
    986
    141
    Yes it does ... FAR BETTER.
    Not really in the same MPG class. However Honda did it, it's a hell of an accomplishment.
    REV
  15. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    Thank you.
  16. bisco
    52,822
    you can congratulate honda all you want. if it turns out to get 50 mpg, it will be the same as the hycam. one just does better on the epa test than the other. the proof is in everyday driving. not ny testers, but by real people in everyday situations. that remains to be seen, and i remain optimistic but unconvinced until i see it. i hope to drive one someday to compare to the 50 mpg we are getting in the hyacc on a day to day basis. i do realize (and so do the manufacturers) that people purchase based on the maroney sticker, and that could boost hyacc sales initially over hycam. but whatever the real world numbers turn out to be, it will play out in the marketplace at some point, along with a proven hybrid system and batteries vs new tech and a company with poor hybrid history.
    xpcman likes this.
  17. bisco
    52,822
    i realize that. i'm just saying that real world prius numbers depend on your driving style, location and etc., hyacc will too. not everyone will get epa mileage. some will, some will do better and some will do worse, just like prius.
  18. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    And it's pretty easy to get better than the EPA estimates on the Prius. The Accord makes me nervous, like you said, until real world results have been extracted from owners.
  19. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    I agree that comparing the current Prius to the hybrid Accord makes the Accord look good. Over the next year or so we will begin to learn if the Accord lives up to its promise.
    When Akio Toyoda took over heading the company he was pretty vocal about wanting to put style and fun back into Toyota products. I think that he has succeeded on this front and I hope that some of this rubs off on the next generation Prius - if it does the new Prius could actually be a bit of fun to drive.
    I'm planning keeping my 2009 until my 14 year old starts driving then give it to her. But if I were looking to buy a new car today I'd probably go with the new Mazda 3 wagon - beautiful car, solid company and good fuel economy and best of all I could get it with a stick.
  20. revhigh
    986
    141
    Hycams DO NOT get anywhere near 50 mpg on a Regular basis. They get more like 38 or 39 overall. The V can't even get 50 mpg regularly ... It gets 41-43 overall.
    Flat out making things up doesn't help your argument.
    I realize most here are Toyota fanbois, and that's to be expected, I am too, but that doesn't stop me from being objective about another product. I've read around 10 reviews on this car and virtually EVERY ONE stated that it was easy to achieve near to or better than EPA estimates. Honda reliability is also not an issue ... Same as Toyota.
    I know plenty of people that envy the mpg that I get in my Prius, but wouldn't buy one simply because of the look and the stigma .... We now have a mainstream looking car, that's bigger, more comfortable, drives better, is FAR quieter, has FAR better interior materials, Prius like mileage, and Honda reliability. I'm betting that the new Accord, when it becomes available in sufficient quantities, steals a boatload of upscale Prius sales, which can only force Toyota to make their Prii even better.
    Now that the public has been shown that they CAN have it all, and don't have to settle for driving a weird looking appliance type car, that's boring to drive ... And can have a decent looking car that STILL gets great mileage ... I think they'll embrace hybrids even more, which can only make the entire hybrid market better.
    Face it .... Toyota has been slacking off due to the Prius being so dominant ... Now Honda's proven you don't have to drive a stupid looking car with a really crappy hard plastic interior in order to get 50 mpg. Honda's breached the 50 mpg barrier primarily with mechanicals ... Not exterior design, which Toyota, up till now, had pretty much convinced the public was an absolute necessity to achieve the mileage.
    REV
    BrianPB likes this.
