Upstream O2 Sensor removal
Discussion in 'Gen 2 Prius Technical Discussion' started by donzoh1, Sep 21, 2025.
  1. donzoh1
    donzoh1 Active Member
    450
    153
    Lenexa, KS
    Why is there a heat.shield on the upstream sensor? Why isnt it just a bit larger so I can actually get a tool on it? I'm trying to do a.back pressure test to see whether the catalytic converter is clogged. I ran thru some large puddles and I'm now getting code P0420. Im thinking I broke the Cat.
  2. Tombukt2
    Tombukt2 Senior Member
    13,871
    2,521
    Durham NC
    Why not just unbolt the cat back and run something like a fish tape see if you hit the brick . That's a stretch. Unless ya smashed the converter into ground or asphalt or such . Breaking cause of fast cooling ? Meh
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
