URGENT About to buy 2010 Prius IV with 73k miles original owner, Advice on problems and price?
Discussion in 'Gen 3 Prius Main Forum' started by TheGrayt1, Oct 18, 2020.
  1. Leadfoot J. McCoalroller
    8,090
    7,571
    Pennsylvania
    2018 Prius c
    Well, now that you've got the car I guess it's time to figure out service and care.
    Don't take it to a Toyota dealer, they will eat you alive. It's a bad idea to take any 10+ year old car back to the dealer anyway- they've largely forgotten it (or are too new to have learned it) in favor of the newest models. Their rates are higher and the management is motivated to rate your car as a rolling wreck so that you'll be pressured to trade it in.
    Now is a good time to locate a hybrid-friendly neighborhood garage. Hopefully you won't need them for a while, but always good to have it worked out in advance.
    Congrats!
    dig4dirt likes this.
  2. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    No worries. Once you get regular knocks and prep to clean the manifold and egr, you’ll know where to find the occ thread.
    51,965
    i would call it 'a very good idea'.
    we don't know what causes oil burning and blown head gaskets in some cars and not others. it may be driving style, maintenance, tolerances, or something else.
    no one can predict if your car will be a problem or not. you have to decide whether it is worth the trouble or risk.
    Attila Fekete and Evoking like this.
  4. fotomoto
    fotomoto Senior Member
    5,638
    3,814
    So. Texas
    CONGRATS! (y)
    Just use some common sense and treat those areas with care. Give the whole bay a good spray, soak with the cleaner for a bit (scrub the worst areas) and spray off. Leave the hood up and let air dry. Next liberally spray with a good plastic care product (my personal recommendation is 303 Aerospace Protectant which is expensive but amazing), let soak in for a long time (even overnight) and the wipe off. Good for about a year and the next time will be MUCH easier.
    Results on a 22 year old motorcycle with the above method:
    GOOD LUCK!
  5. orenji
    orenji Senior Member
    5,887
    3,488
    Your assumptions are inaccurate. 0W-40 offers a wide range of driving temperatures. 0W-20 offers less. Have you heard of CAFE standards. If not look it up. There is a reason almost every manufacturer in USA is using 0W-20 oil and it’s not to provide maximum protection of your engine.
  6. Mendel Leisk
    41,479
    I would not use spray. Dust, vacuum, damp cloth. Remove the intake air snorkel and air filter box will help.
    There ARE sensitive electronics and connectors. At least two members have toasted very expensive AC compressors, just spraying away.
  7. Evoking
    Evoking Junior Member
    91
    16
    Pomona
    Thanks bisco for your help I really appreciate it I’m going to order one right now and everything I’ll need.
  8. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Wait, you mean you haven’t seen the nutsaboutbolt engine bay cleaning video?
  9. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    You be gettin poo pooed like me when I tell them I full lower grill block during summer seasons also.
    hill likes this.
  10. Attila Fekete
    Attila Fekete Member
    164
    59
    Budapest, Hungary
    Could someone show me manual suggesting 0w-50 oil for Canada?
    CAFE standard is quite irrelevant in Europe, but all manufacturer try to reduce consumption, I agree. And oil is part of that.
    But still, using a 0w-20 oil will give you better lubrication at 104 Fahrenheit than a 0w-40.
  11. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Orenji is suggesting that a thicker oil will be fine to run on safely given the car is in the ideal circumstances and or climate, it might even be beneficial to do so.
    I’m surprised no one mentioned 5w or 10w will be safe for hotter climate. Mine is 5w and car is garaged so it’s never below 40f for cold starts, but with ZDDP in the 1,200 ppm in my oil, the oil is more of 10w.
    #31 Grit, Oct 19, 2020
    orenji likes this.
  12. Attila Fekete
    164
    59
    Budapest, Hungary
    That’s fine, but I wouldn’t say just use 0w-40 instead of 0w-20 generally.
    For example I use the car for short trips - less than 4 miles, I have no garage. I will definitely won’t change to thicker oil.
    So what is the benefit of using 0w-40?
  13. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    At 104f, barely any difference because both oil are rated at 0w under low temp engine start ups.
    orenji likes this.
  14. Attila Fekete
    164
    59
    Budapest, Hungary
    Fir me the 71 vs 44.8 cSt is a significant difference. Mobil1 10w-40 oil has 107 cSt.
    Even the 5W-30 has cSt 70 at 104 F.
    SAE viscosity grades can cover quite wide ranges.
  15. orenji
    5,887
    3,488
    It’s been discussed many times and others have posted their countries owners manuals showing the higher weigh oils being recommended by Toyota. Search Priuschat and you will find your answers. Or continue to run 0W-20, it’s not my car.
  16. Mendel Leisk
    41,479
    Canada's 0W20, at least for 3rd gen. 4th they're saying 0W16? :rolleyes:
  17. orenji
    5,887
    3,488
  18. orenji
    5,887
    3,488
    As you can see in the above post for Prius in Australia that thicker oil is used. With the advantages of. 0 weight oil like 0W-40 you won’t have cold climate engine starting issue and have the extra protection of the 40 weight.
  19. Attila Fekete
    164
    59
    Budapest, Hungary
    Australia is not Canada. They don’t really have winter.
    So what is the advantage of using 0w-40 oil - by the way, I don’t see it listed above.
    I still don’t see it proved that 0w-40 is better everywhere to be used.
  20. orenji
    5,887
    3,488
    OW Is the weight of the oil when cold. Nothing will flow better then a 0W oil. The 2nd number is the thickness of the oil weight when hot. The thicker the oil the more protection you will have. OW-40 is one of the best all round oil weight you can buy. BTW only 0W-40 Mobil 1 is a true synthetic oil within the Mobil 1 line.
    The above booklet show 40 and 50 weight oil for the Prius as well as the temperature chart for selecting oil based on your regional temperatures.
