Urgent Help! Battery issues
Discussion in 'Newbie Forum' started by Adam R, Jan 24, 2018.
  1. Adam R
    Adam R New Member
    Cincinnati
    I just replaced the 12v in my 2012 Prius C two. I started the car fine afterwards three times. I was able to take the car to Autozone to make sure the old 12 v was the issue and it was. I get home. Put all plastic covers back in place and now I tried to start the car again and it’s giving merge “check the hybrid system” warning. What the hell did I do? I really don’t see how there can be something wrong with the hybrid system when the battery seems to have had no issues keeping a charge and my gas mileage has been fine. The total miles for my car is 137316. And that seems too soon for the hybrid battery to kick the bucket.
  2. Adam R
    Adam R New Member
    Cincinnati
    So. I knocked the battery release. I put it back into it’s up position. The car starts again but still has the warning up.
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Unhook the battery for 10 seconds to clear any codes, then reconnect.
    See if that clears things?
    Raytheeagle likes this.
  4. Adam R
    Adam R New Member
    Cincinnati
    Unhook the hybrid battery or 12v?
  5. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    This. ^^^^
    And, did you charge the new 12 V before installing it ??
    If not, you should do that NOW; not necessary to disconnect or remove to do that.
  6. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    Sorry. I should have been more clear.
    Unhook the 12v battery.
  7. Adam R
    Adam R New Member
    Cincinnati
    I don’t know much about cars so excuse my ignorance but do you have to charge a brand new battery? And how do you do that?
  8. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    Brand new battery *should* come already charged. Most places check them before they send you on your way, but not always.
  9. Adam R
    Adam R New Member
    Cincinnati
    Yeah I had to buy from a Toyota dealership so I’d like to think they wouldn’t give me one not charged. And like I said the car started three times with no issue until I knocked the hybrid battery release.
  10. Adam R
    Adam R New Member
    Cincinnati
    I apologize for showing off my laziness but would I need to unhook both positive and negative cables or can I just unhook the negative for 10 seconds and get the same result?
  11. VFerdman
    VFerdman Senior Member
    1,200
    1,221
    Western Massachusetts
    Just the negative or whichever is easier.
  12. Mendel Leisk
    42,384
    Would multiple start ups do that also? Well at least for the check hybrid system warning? Or no?
    I appreciate it would not erase any stored codes, but maybe that's for the best?
  13. Adam R
    Adam R New Member
    Cincinnati
    I unhooked the negative for ten seconds. That seems to have solved it. Fingers crossed that I don’t see anymore issues. Thank you for the help everybody!
    Raytheeagle, RCO and Mendel Leisk like this.
  14. Sam Spade
    2,036
    1,024
    2017 Prius c
    SOMEBODY has to. You do that with a battery charger.
