urgent! need help with speaker install!
Discussion in 'Prius c Audio and Electronics' started by col127, Mar 30, 2013.
  1. col127
    col127 Member
    345
    Illinois
    hey all,
    started trying to do my speaker install today but i ran into problems:
    first, i was able to get the door off, but only partially. there's wires attached to the door lock (on the backside) - how do you disconnect it? i couldn't figure it out so while i had the door panel "off" it was still attached to those two wires. door_lock.JPG click to enlarge.
    second, the speaker is attached to the door with a weird 'screw' - it's not a regular crosshead. it's simple a circular dot - how do i get that off?! i've never seen that before! speaker.JPG click to enlarge
    i've attached pictures of both. thanks for your help!
  2. frodoz737
    frodoz737 Top Wrench
    4,803
    2,560
    33
  3. fun420fun
    fun420fun Junior Member
    The two wires that are a attached to the door are for the lock/unlock and opening the door to get out. The white and green plastic pop in and out, then you remove the balls out of the joint, just remember where the green and the white go. Rivets are what is holding the speakers. The easiest way to remove the rivets is to get a big enough drill bit and drill them out.
  4. col127
    col127 Member
    345
    Illinois
    thank you thank you :)
