URGENT - OVERHEAT - Red Triangle & Temp Icon on road trip (Live From Starbucks)
Discussion in 'Gen 2 Prius Main Forum' started by SRQ, Jul 15, 2021.
  1. ToyotaGal
    ToyotaGal Member
    191
    85
    Millis, ma
    Thanks for posting g this thread. I saw it and thought I never changed the belt nor did I know if the previous owner had changed it. I have 185300 miles on her. I decided to change the belt. The old one was cracked and brindle. No signs at all.
  2. SRQ
    SRQ Member
    158
    56
    I really am grateful that the experience I went through helped someone else avoid the situation altogether. That made it worth it.
    ToyotaGal and Henrik Helmers like this.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Be aware you must check the radiator level by taking the radiator cap off not by looking in the over flow plastic container. Rad could be empty and overflow full.
    Take the black plastic cover off the top of the rad the cap is under there.
    Leave the screws out if that cover the hood traps it closed so it will easy and quick to check level.
