URGENT:Please make it clear about Tactrix OpenPort2.0
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AbuS3ood, Oct 19, 2010.
  1. AbuS3ood
    AbuS3ood Member
    113
    Jordan
    URGENT:Guys Please make it clear about Tactrix OpenPort2.0
    Hi all,
    I have read too much threads about Tactrix OpenPort2.0 but found nothing with specific answer regarding to Gen II prius, so please guys who tried the cable answer us
    1. Is it fully compatible with TechStream 5.xxxx in reading and setting parameters????
    2. if not what is the missing features???
    3. what is the difference between it and Mongoose other than PRICE?!?!
    4. can it add new keys(unused) to prius via TechStream ?
    please guys i need your answers ASAP.
  2. AbuS3ood
    AbuS3ood Member
    113
    Jordan
    whats wrong guys? 112 views and no replies????
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I would like to know too. I don't think many of us own one to provide you the answer.
  4. Patrick Wong
    18,200
    6,493
    I suggest that you contact the vendor directly with your questions.
  5. AbuS3ood
    AbuS3ood Member
    113
    Jordan
    i already did and they didn't answer, they mention in the website it support techstream but without details( maybe only reading data), I live far away and will pay much $$$ for customs that y am asking b4 i place the order.
  6. AbuS3ood
    AbuS3ood Member
    113
    Jordan
    here is their reply after 4 days
    Yes –our hardware does support Toyota TechStream software, assuming that the model you are working with is CanBus supported. As we do not write reflashing software for Toyota model vehicles, and do not work with them directly, we are not able to provide details, other than the information listed on our website.
    no clear answer.
  7. RobH
    RobH Senior Member
    2,374
    987
    70
    Sunnyvale, California
    I think it's a high probability that the Tactrix works with the Toyota CanBus. The real question is whether it works with the 9.6 Kb data rate KWP bus where many of the Gen2 Prius ECUs are connected. Keyfobs, option setup, and TPMS are all KWP on Gen2. Some of the ECUs that are KWP on Gen2 have moved to CAN on the Gen3, but TPMS is still on KWP even on the Gen3.
  8. AbuS3ood
    AbuS3ood Member
    113
    Jordan
    here is the technical details from the site
    Technical Details
    • 72Mhz 32-bit processor
    • USB 2.0 full speed device
    • Field upgradeable software
    • Supports these major OBD protocols:
      • CAN 2.0 (CAN/ISO15765)
      • K-line (ISO9141/ISO14230(KWP2000)/dual K line)
      • J1850 (PWM/VPW)
    • J2534 PassThru support with Windows DLL
    • Standalone datalogs to microSD / microSDHC card without a laptop
    • Able to apply GND or 5V-25V to OBD pins 1,3,9,11,12,13 or AUX 2.5mm stereo connector
    • Able to log from Innovate Motorsports 2.5mm stereo MTS data bus
    • RGB status LEDs
