USA vs. EU Prime/PHV
Discussion in 'Prime Main Forum (2017-2022)' started by Tideland Prius, Apr 17, 2017.
  1. Tideland Prius
    16,683
    PriusChat is US-based but we are getting more and more international owners/members and it's easy to get lost in all the US-specification talk. This thread helps differentiate between the two regions and hopefully shine a light on the differences (either in terminology or actual differences in features). The most obvious is in the name. US/Canada uses "Prius Prime". The EU uses "Prius PHV". I've attached a PDF listing the specifications for USA, Canada, UK and Japan.
    USA EU Japan
    1 Exterior
    2 Solar Roof - Opt Opt
    3 Rear LED Foglight - Std Opt1
    4 215/45R17 Tires on 17" Alloys - - Opt
    5 Interior
    6 Cloth Fabric Upholstery Std Std Std
    7 SofTex Synthetic Leather Upholstery Opt - -
    8 Leather Upholstery - Opt Opt
    9 Automatic Climate Control Std - Std
    10 Dual-Zone Automatic Climate Control - Std -
    11 Charge Schedule 4.2" or 11.6" MID 4.2" MID 4.2" or 11.6" MID
    12 Safety
    13 Full Speed/All-Speed/All-Range Dynamic Radar Cruise Control / Adaptive Cruise Control with Full Stop Functionality Std Std Std
    14 Pre-Collision System/Pre-Crash Safety System Std Std Std
    15 Lane Departure Alert w/ Steering Assist/Lane Departure Alert w/ Steering Control Std Std Std
    16 Automatic High Beam Std - -
    17 LED Array Adaptive High Beam N/A Std Std
    18 Road Sign Assist - Std -
    19 Adjustable Speed Limiter - Std -
    20 ITS Connect - - Opt2
    21 Drivetrain
    22 Hybrid Mode Std Std Std
    23 EV Drive Mode Std Std Std
    24 EV City Mode3 - Std Std
    25 EV Auto Mode Std - Std
    26 CHG Mode Std Std Std
    27 Audio
    28 AM/FM Std Std Opt
    29 CD Player Std Std Opt
    30 DVD Player - - Opt
    31 USB Audio & Video Std Std Opt
    32 3.5mm Auxiliary Audio Jack Std Std Opt
    33 Terrestial Digital TV - - Opt
    34 Bluetooth Streaming Audio Std Std Opt
    35 Wi-Fi Connection Support - - Opt
    36 6 Speakers Std Std Std
    37 JBL Audio w/ 10 Speakers Opt Opt Opt
    38 Navigation System Std Std Opt
    39 7" LCD MFD Std - -
    40 8" LCD MFD - Std -
    41 9" LCD MFD - - Opt
    42 11.6" HD LCD MFD Opt - Opt
    Notes:
    1. Part of Cold Weather Specification. Standard in Hokkaido district
    2. ITS Connect is part of the Vehicle-to-Infrastructure technology
    3. EV City Mode is a lower power mode meant to extend the electric range and thus does not have dual-motor capability
    If anyone's curious, there are also differences between Canada and the U.S. In Canada, most of our labels are now symbols and are no longer words. e.g. Wipers - Type A is Canada, Type B is U.S.
    See attached PDF for a table of features
    #1 Tideland Prius, Apr 17, 2017
    giora and unicorn like this.
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    How much does EV City Mode extend electric range?
  3. Tideland Prius
    16,683
    Think of it like ECO mode - it provides a bit more resistance on the pedal to limit unnecessary harder acceleration.
    priuscatprimeguy likes this.
  4. priuscatprimeguy
    2,730
    2,640
    or I could go down the side streets where I live, not exceeding 25MPH:D
    Tideland Prius likes this.
  5. Ferrarilover
    Ferrarilover Active Member
    185
    168
    Manchester, UK
    From reading the brochure it seems that the version here in Britain does the same as the US.
    This is from the brochure here in the UK
    iPhone ?
  6. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    Rear fog light is mandatory equipment in EU.
    Correct me if I'm wrong but automatic high beam and array LED comes standard also in US.
    There is also JBL audio system option in EU, do you get that in US?
  7. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Automatic Hi-beam, LED array, front LED foglights, HUD, Stolen Car Locator, and JBL 10 speaker system are standard in U.S. Prime Advanced. This is only partial list of toys!
    Samprocat likes this.
  8. Trollbait
    12,832
    Has EV Auto been confirmed as Exactly the same as EU EV? There was some conflicting info in the other thread.
    LED array and LED adaptive array are two different things. The Prime has LED arrays in all markets. Because of outdated vehicle codes, the LEDs can only operate in a low or high beam manner. So when an oncoming car is detected, the auto high beam function turns all the headlight output down to low beam. Adaptive headlights will only turn down the output that is hitting the oncoming car, leaving the rest of the are lit by highbeams.
    Crowmag Naman likes this.
  9. unicorn
    unicorn Member
    48
    EU
    I wouldn't separate Britain from EU :) ...
    I mean, there is only one Prius Plug-in Manual for EU, see Toyota Europe
    that can be found on Toyota UK as well.
    If it's possible, I would suggest the 3rd column for Japan.
  10. Ferrarilover
    185
    168
    Manchester, UK
    The plug in for the uk has adaptive headlights that can turn down any one if the 8 beams.
    iPhone ?
    giora and Tideland Prius like this.
  11. Tideland Prius
    16,683
    Thanks!
    No LED Array.
    Yes, JBL is optional (well, it's standard on Advanced trim level)
  12. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    I think this it's misleading. It.s not about pedal response mapping (which of course is an included but separate and different feature of the car), this mode actually reduces the car's available power by using single and not dual motors.
    The effect upon range is that Toyota claim up to 39 miles range in EV city.
  13. GT4Prius
    530
    412
    Cumbria, UK
    Excel
    One manual doesn't necessarily mean one spec. In plenty of places the manual says "if equipped".
  14. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    From Toyota engineer when i was on Auto show he said
    That high beams will not be active if the camera and sonar sense moving incoming car where drivers side LED will deam one of LED projectors
  15. unicorn
    unicorn Member
    48
    EU
    I agree, but we can see one strategy for all EU countries.
    At present, only the expensive Advanced Level (+ Solar or Parking Pack).
    Anyway, "if equipped" is an interesting point in the EU Manual. There are two groups:
    #1 (if equipped): HUD, BSM (Blind Spot Monitor), S-IPA (Simple Intelligent Parking Assist System), ICS (Intelligent Clearance Sonar), Toyota parking assist-sensor, Mode 3 charging cable, Solar charging system, Double locking system, Alarm, Intrusion sensor, speed unit changing (km/h mph), Auxiliary boxes Type B/C, Wireless charger
    -> that can be explained by Solar/Parking/Alarm Packs.
    #2 (if equipped): Traction Battery Cooler, Charging mode "Departure" incl. Air conditioning-linked setting (“Climate Prep”),
    -> that is difficult to explain, moreover, it's only a case of the EU Manual (pp.142)
    Any ideas?
    Functionality (EU Manual):
    1. Traction Battery Cooler -> "When the hybrid battery (traction battery) is hot, this function protects it by using the vehicle air conditioning to cool it before charging is carried out." ... "When the charging mode is set to 'Start', cooling starts at the set charging start time. When the charging mode is set to 'Departure', cooling starts approximately 30 minutes before the charging start time."
    2. Charging mode 'Departure' -> "Starts charging to finish at the set time. When this setting is selected, the air conditioning linked function can be used."
    #15 unicorn, Apr 19, 2017
  16. GT4Prius
    530
    412
    Cumbria, UK
    Excel
    Trollbait is correct. The system can selectively switch off lighting for PART of the road ahead to avoid other drivers being dazzled. It can do more than this too. It
  17. Trollbait
    12,832
    Isn't that just the NEDC number? I'd be a little surprised if the dual motors are even used on any official test cycle.
    Which is neat, but we can't get it in the US. Our regulations are the reason for that difference.
  18. ajpn
    ajpn Junior Member
    30
    16
  19. Tideland Prius
    16,683
    Please see the first post. I've attached a PDF of the features for Canada, USA, UK and Japan. Hope it was worth it. It took several hours.
    giora likes this.
  20. Tideland Prius
    16,683
    Added another difference. The charging schedule in the EU can only be adjusted through the 4.2" MID, using the pad.
    Vehicles in the US and Japan with the 11.6" screen can add/edit/delete schedules using the 11.6" MFD.
