USB-C Device Compatibilities
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by '65 T-Bird, Mar 14, 2024.
  1. '65 T-Bird
    '65 T-Bird Junior Member
    Sunnyvale, CA
    2024 Prius
    Even though the manual indicates USB-C Thumb-Drive can't be any greater than 32GB, does anyone know if a 64GB device will work?
    Also, does anyone know if 'Ultra Speed(150MB/Sec)' USBs will work on/with 5th Generation Toyotas, or are SDHC devices the 'Max Speed' that will function correctly?
  2. Hammersmith
    Hammersmith Senior Member
    2,486
    2,544
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Maybe, but you might have to work at it a bit. The car can only recognize drives formatted in FAT16 or FAT32. Pretty much all drives larger than 32GB come preformatted in exFAT or NTFS. You can try and reformat a 64GB drive as FAT32, but you'll probably need a third party file manager to do it. Windows can't do it natively, and I'm not sure if Macs can. And even if you do succeed in reformatting it, I can't guarantee it will work. I haven't tried it myself, so I can't vouch for it.
    And no on the Ultra Speed. The car is using USB 2.0 HS (480Mbps/53MBps) as its interface standard..
    '65 T-Bird likes this.
  3. Lantaral
    Lantaral Member
    66
    31
    US
    2024 Prius
    Yes, larger drives work perfectly as long as they're formatted Fat32.
    Samsung's tiny 256GB drives are factory formatted fat32. Look for model # MUF-256DA/AM.
    Drive speed isn't an issue. The car only needs to read a flash drive quickly enough to play media files. And it can do that.
    #3 Lantaral, Mar 16, 2024
    PACaren, klsprius and '65 T-Bird like this.
  4. '65 T-Bird
    Sunnyvale, CA
    2024 Prius
    Thanks Lantaral; greatly appreciate your input, but think I'll just go with Toyota's suggested thumb drive specs to avoid any issues. I used a 64GB drive in my 2016 Prius, but it had difficulty 'seeing' all 7K+ individual files/tunes loaded on thumb drive. When creating the file structure, I did certify all other Toyota parameters were met i.e. total number of folders/subfolders, etc...
    I accidentally 'shot myself in the foot' by erasing previous 'music library 44GB' on same drive by 'reformatting' it, then copying 'New Library 48GB' onto drive to add/update same, etc... Before I did so, the 64GB drive worked just fine and did recognize all 5K+ files on the same drive.
    Thanks Hammersmith; greatly appreciate your quick 'detailed' response and suggestions. Think I'd better stick with Toyota's suggested thumb drive specs to avoid any issues.
    #4 '65 T-Bird, Mar 17, 2024
  5. '65 T-Bird
    Sunnyvale, CA
    2024 Prius
    Update: Since posting my inquiry, purchased 64GB USB-C/USB Dual stick; it's a Verbatim USB 3.2 formatted as FAT32. After completing copy/paste of my entire 48GB Music Library to it, plugged it into my 2024 XLE, but the Audio System did not find/recognize it; may have been due to the 3.2 speed
    Had also ordered 'USB to USB-C Adapter' and used it for my previously tested SanDisk 64GB FAT32(in 2016 Touring) for many years; it works fine, except I can no longer 'Select Complete Folders' and 'Shuffle Play' same. Will start 'new thread' re this issue.
  6. Lantaral
    Lantaral Member
    66
    31
    US
    2024 Prius
    The 3.2 speed is not the issue. USB drives are designed to fallback to the speed of the device to which they're connected.
    Try reformatting the drive in fat32 and copy a few mp3 files to it. And make sure it's plugged into the correct port, believe only one of the car's USB ports is a data port, the rest only charge.
  7. Eddie F
    Eddie F Junior Member
    28
    Windsor, Canada
    2024 Prius Prime
    SE
    I'm using my older thumb-drive USB3 - 256Gb with an adapter UBB-C / USB3. As long as you follow the <=255 files per folder rule - It works fine.
    Lantaral likes this.
  8. klsprius
    klsprius New Member
    usa
    2023 Prius
    Confirmed working in my 23 Prius LE:
    SAMSUNG Type-C™ USB Flash Drive, 64GB, Transfers 4GB Files in 15 Secs w/Up to 300MB/s 3.13 Read Speeds, Compatible w/USB 3.0/2.0, Waterproof, 2022, Blue, MUF-64DA/AM ✅
    Came formatted as FAT32.
    Did not work:
    Verbatim 32GB Store ‘n’ Go Dual OTG USB 3.2 Gen 1 Flash Drive for USB-C Devices – 2 in 1 Type C Thumb Drive❌
    Even when formatted to FAT32.
  9. Sharol
    Sharol Member
    162
    76
    Kansas, USA
    2023 Prius
    I'm using a 128 gb flash drive. Just understand that a fat32 partition (and it is a partition) is only 32gb, and the car won't be able to see the unformatted portions.
  10. Serenity Now
    Serenity Now New Member
    United States
    2024 Prius Prime
    Luckily, you can format almost any size USB drive as FAT32 using utilities like "Rufus". I'm using a 128gb Samsung USB C in my 2024 Prime XSE - it's awesome. I can utilize and access the entire 128gb partition!
  11. Sharol
    Sharol Member
    162
    76
    Kansas, USA
    2023 Prius
    good to know. Is it in partitions or does it just fool the reader into thinking it is.
  12. ChapmanF
    19,020
    While I try pretty hard not to be an expert on details of FAT partitioning, what I can glean about it suggests that 32 GB has never been an inherent limit to partition size. The marketplace has mostly been choosing other formats for devices larger than 32 GB, but that doesn't mean you can't make a FAT32 partition bigger than that.
    If this article is accurate, you don't run into an absolute limit (where the FAT32 format can't cover the whole drive) until 16 TB (article also mentions a "practical limit" around half that size). Probably won't be running into that with a USB stick for some music in the car.
    According to the article, the Windows GUI format tool won't give you the FAT32 option for a partition larger than 32 GB, but the 'format' command run from cmd or PowerShell can, and so can 3rd-party utilities.
  13. Lantaral
    Lantaral Member
    66
    31
    US
    2024 Prius
    As posted above, Samsung's tiny 256GB drives are factory formatted fat32. All of the drive's space is usable. Works properly out of the box, no formatting necessary.
    Serenity Now likes this.
  14. Serenity Now
    United States
    2024 Prius Prime
    It's just one single partition.
  15. Eddie F
    28
    Windsor, Canada
    2024 Prius Prime
    SE
    I used both of these drives formatted to FAT32:
    Lexar JumpDrive S45 128GB USB 3.0 Flash Drive - LJDS45-128ABNL
    and
    SanDisk Ultra Fit 128GB USB 3.0 Flash Drive (SDCZ43-128G-GAM46)
    with a USB to USB-C adapter.
    More critical issue is a number of files per folder. It shouldn't exceed 255.
    #15 Eddie F, May 14, 2024
