USB connect/disconnect, Pandora tethering issues - resolved!!!
Discussion in 'Prime Audio, Electronics, and Infotainment' started by Dmitriy Sokol, Feb 22, 2017.
  1. Dmitriy Sokol
    Dmitriy Sokol Active Member
    112
    108
    Annapolis, MD
    I know that many of us had these intermittent connect/disconnect USB issues and I couldn't get my Pandora APP on Entune to initiate most of the time. I tried all my genuine Apple cables, to include a brand new one. Nothing helped. Until today. I got an Anker Powerline + cable from Amazon and boom!!! Everything works as it should. Hope this helps someone.
    mr88cet and I'mJp like this.
  2. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    This is why this site is so valuable.
  3. Optimus PRIME
    Optimus PRIME Active Member
    180
    141
    SF Bay Area
    I am sorry that I missed this discussion from previous threads, otherwise, I would have mentioned the Anker PowerLine+ cable. I have noticed the charging problems from the USB port from the start with my other cheaper cables and the Anker cable did resolve that for me.
    I have been using a Cigarette adapter charger with 2 ports as well, and the Anker cable always works while my cheaper cable would not work well sometimes either.
    so yes, the ANKER POWERLINE+ cable is totally worth the extra money when compared to other cheaper alternatives.
  4. Optimus PRIME
    180
    141
    SF Bay Area
    I bought the 3 foot length cable and it looks great and feels great. It is also soft and flexible enough
  5. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Thanks!
    So, do the Anker cables help with audio via USB (and perhaps just Internet-connection data?), or do they just help with charging?
    I gather that, when you say the "Pandora App on Entune," you're talking about that on the P.Prime itself, as opposed to that on your smartphone?
    iPhone ? Pro
  6. Dmitriy Sokol
    112
    108
    Annapolis, MD
    I have the same Anker cable as Optimus. I am not sure if it improves the rate of charging, but it maintains a stable connection to your car. Other cables cause your phone to go through connect/disconnect cycles for no apparent reasons (at least in my experience).
    Yes, I was referring to the Entune Pandora app. 9 out of ten times, I would get a "Tether error" message, instead of a connection. I would end up using an app on my phone and a USB connection (which wasn't stable to begin with).
    Overall, I find Entune to be finicky and underdeveloped. I hope Toyota will be addressing the issues via future updates.
  7. Optimus PRIME
    180
    141
    SF Bay Area
    Even after the 2/22 update for EnTune, this app would still not open correctly on my iPhone 6s until I restart the phone. It is too bad that it is so unstable and undependable.
  8. Jordango
    Jordango Junior Member
    Huntington Beach, CA
    Thanks for the recommendation on the Anker cable! I ordered one. Hopefully it will help reduce the USB error messages!
  9. bb4srv
    bb4srv Active Member
    140
    107
    2018 Prius Prime
    Technology
    I picked up a brand spanking new 2018 Pprime. Same thing happened with me. As soon as I plugged the OEM apple cable to the USB port of the car and then to my phone, the connection would connect/disconnect/connect/disconnect, etc. for 4-5 cycles. It may or may not connect. I though there was something wrong with the audio system until I found this thread.
    I picked up Anker Powerline+ and mysteriously it now connects fine. If the unit doesn't read it as an Music Device, then reboot the phone and it should read it as an Ipod device. Thanks to whoever provided this tip!
  10. mr88cet
    2,313
    1,335
    Austin, TX
    I “got the memo” about the Anker cable prior to getting our P.Prime, and I’ve rarely had any problems with USB connections.
    Well, probably... I say that because I do occasionally find that I can’t “remote control” the iPhone over USB. That is, the sound plays fine, but if I try to select a different playlist or track forward or the like, it doesn’t. When I unplug and re-plug it, that often takes care of it. Or switch over to Bluetooth...
    Typed by Mr88cet’s dancing thumbs
  11. LoliKami
    LoliKami Junior Member
    31
    Los Angeles
    I got to get this chord. My iPhone X new line was working fine for a few months and then it starts doing it again.
  12. mr88cet
    2,313
    1,335
    Austin, TX
    To clarify, although “remote control” doesn’t always work, the sound quality is considerably better than Bluetooth, I haven’t seen crashes or the like with the Anker cable.
  13. LoliKami
    31
    Los Angeles
    update to getting the Anker line:
    Did help for a week and then it's bad again.
