USB memory
Discussion in 'Prime Audio, Electronics, and Infotainment' started by Bobdski, Jun 3, 2017.
  1. Bobdski
    Bobdski Junior Member
    37
    Rockaway, NJ
    What's your experience? I have > 4000 songs on my USB drive but the system only plays about the first 270. Does this happen to you?
  2. DickPhillips
    DickPhillips Member
    89
    58
    Mount Vernon, WA
    I haven't tried using my thumb drive yet but I think the instructions say it will only see that 270 or so per folder so maybe if you break down your collection into folders with 265 or so per folder, you may be able to cycle through them. Like I said, I haven't tried this yet myself.
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    What.....read the instructions ???
    Blasphemy !! :eek:
    :ROFLMAO:
  4. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Use the search tool, there is at least one thread in this forum that covers this subject in deep.
  5. fuzzy1
    10,718
    Nothing in this digital world is limited to 270 or 265. The common limits in this neighborhood are 256, 255, or very slightly less.
  6. Bobdski
    37
    Rockaway, NJ
    Nothing in the manual.
  7. Bobdski
    37
    Rockaway, NJ
    Search on USB came up empty
  8. Bobdski
    37
    Rockaway, NJ
    Oddly the track numbers came up as 270 and 271
  9. Bobdski
    37
    Rockaway, NJ
    Folders was a thought I had to, worth a try.
  10. Bobdski
    37
    Rockaway, NJ
    I've been to Herzlia twice in the past year. Stayed in Te Aviv the other 3 times.
    giora likes this.
  11. fuzzy1
    10,718
    My 2012 has two manuals, one for the car, a separate one for the display audio system. Did you check both? And any more added for 2017?
    Mine counts tracks by adding together everything it can see in multiple folders, but no more than 255 files per folder.. Do you have more than one folder?
    There are other restrictions too, including limited file formats. But I'd hope that your Gen4 recognizes a wider selection than my Gen3.
  12. Bobdski
    37
    Rockaway, NJ
    I need the folders. Thanks.
  13. TonyPSchaefer
    14,816
    2,502
    66
    Far-North Chicagoland
    It's in the Navigation and Audio manual. Page 122.
    Maximum number of files per folder = 255
  14. TonyPSchaefer
    14,816
    2,502
    66
    I don't have my Prime yet so I can't test this, but my plan is to just copy my iTunes library to a thumb drive. Since I let iTunes "manage the library" all the files are in their appropriate folders.
    HPrimeAdvanced likes this.
  15. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
  16. Sam Spade
    2,036
    1,024
    2017 Prius c
    Not a true statement.......because you have no way of knowing that.
    Unless you have personally tested out EVERY digital device ever made and is still in use; millions and millions.
    I understand what you are trying to say but that isn't the right way to say it.
  17. fuzzy1
    10,718
    Is this better?:
    "Almost nothing in this digital world is limited to 270 or 265. "
    Tideland Prius likes this.
  18. Bobdski
    37
    Rockaway, NJ
  19. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    For clarification, I was SO frustrated with this. Only about 250 or so songs can be on a single folder. So I made a lot of folders alphabetically.
  20. Bobdski
    37
    Rockaway, NJ
    I just ended up copying folder from my itunes music directory.
    'LectroFuel likes this.
