usb port not working
Discussion in 'Prius c Audio and Electronics' started by bader, Sep 8, 2016.
  1. bader
    bader New Member
    jordan
    i have prius c 2013 two
  2. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    223
    Nature coast, Florida
    Three Touring
    Have you checked for a blown fuse, in your fuse bank? Not sure where it is on the C.
  3. bader
    bader New Member
    jordan
    can you tell me which fuse plz
  4. Eclipse1701d
    645
    223
    Three Touring
    Google is your friend, in this instance.
  5. Shingshing
    Shingshing New Member
    Suffern, NY
    2014 Prius c
    Google is not very friendly in this instance, nor is the owner's manual. I read that the USB port is on the same circuit as the nav system but I don't see the nav system in the list of fuses in the manual.
    #5 Shingshing, Dec 26, 2016
  6. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Old thread but..........the USB port is not compatible with all devices.
    Someone might be able to provide better advice if we knew what kind of device (phone?) you are using and what you are trying to make it do.
  7. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    Also, if you're trying to use the USB port to charge your phone you should be aware that the port is not powered unless the car is turned on.
  8. Pepper65
    Pepper65 Junior Member
    Citrus County, FL
    Anybody else ever get a weird message on display like I did this a.m. about USB drive using too much energy and that it's going to shut down. Here's the kicker: I'm not even using a USB drive at all.
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,783
    2017 Prius c
    But is your PHONE plugged into that connector ?
    My wild guess: that sensor depends on temperature and the BLISTERING HEAT might have
    triggered it.
