USB port
Discussion in 'Prius v Audio and Electronics' started by Dirtnapper, May 19, 2014.
  1. Dirtnapper
    Dirtnapper Member
    110
    MA
    2014 Prius v wagon
    On my Prius v III...I thought I could use the port for charging, it appears not. Anyone - ideas on this? I will also check to see if it will play anything connected. Thanks.
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    My USB port charges my Android cell phone or tablet.
  3. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    All USB-2 ports are required to offer 500mA at 5 volts +/- 10%. AFAIK, the Prius does. If they don't they can't officially be called USB.
    Whether a given device is able to charge on such a port is a separate question, and some can't.
  4. Dirtnapper
    Dirtnapper Member
    110
    MA
    2014 Prius v wagon
    I just tried a couple of Android phones, no charge. I could not play any of the mp3's off them also; no option for USB under audio.I think we might have an ipod, if so I'll try that.
  5. nsfbr
    nsfbr Member
    112
    30
    Northern Virginia
    2013 Prius v wagon
    Well that's odd. Mine charges my phone just fine. It also plays tunes just fine. I've not tried to see if it has enough oomph to charge my iPad, but I might try sometime soon.
  6. Dirtnapper
    Dirtnapper Member
    110
    MA
    2014 Prius v wagon
    I am trying to locate the ipod, but I tried several phones and usb cords, nothing. I even tried a Sandisk stick with some mp3's; I think I saw that the Prius C can take memory sticks. I have a feeling that is does not work so I'll have to go back to the dealer.
  7. Midesaka
    Midesaka Junior Member
    Southern MS
    I couldn't get my USB port to charge an iPod Classic. I haven't tried charging my Galaxy S4 through it, instead using a PowerGen 12V adapter which works very well.
  8. Cristino
    Cristino Junior Member
    46
    24
    Bayamon, Puerto RIco
    On some Android phones, you have to select what to do when connected to an USB port: charge only, Media Device (MTP) access, Mass Storage access, etc.
  9. nsfbr
    nsfbr Member
    112
    30
    Northern Virginia
    2013 Prius v wagon
    I've confirmed my Prius v Five USB port (on the center console, I don't know if there is another somewhere) charges both my iPhone 5 and my iPad Air. Previously, I've had older iPhones charge from it. I don't recall using it on an iPod.
    I have no Android devices, so I have no idea. Maybe it is a sign.
  10. Zephyr7
    Zephyr7 Member
    301
    28
    a Prius v III comes wih display audio and navigation. I checked it will charge android and play MTP devices.
    if u upgraded the radio then it does not support MTP, it should however charge.
  11. Dirtnapper
    Dirtnapper Member
    110
    MA
    2014 Prius v wagon
    I just came form the dealership, after 3 hrs.... they replaced the usb socket, and it didn't work. Further checking revealed that when it was assembled someone put the cable in the wrong port on the junction box behind the audio system. Works ok now.
    Cristino and JimboPalmer like this.
