USB ports all inactive
Discussion in 'Prime Main Forum (2017-2022)' started by Northerner, Mar 4, 2023.
  1. Northerner
    Northerner Active Member
    121
    103
    Midwest
    2020 Prius Prime
    None of the USB ports are active - back seats and front. Apple CarPlay won’t work either. We tried two different cords and two different phones so it’s the car. Any ideas before I bring it to the dealer?
  2. BiomedO1
    BiomedO1 Senior Member
    4,537
    2,389
    Left Coast
    Check the fuses, inside panel and outside panel?
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Does the head unit work otherwise ?
    AM/FM......SAT......GPS......????
    If it hasn't been "messed with", I hope you are still under warranty.
  4. Northerner
    121
    103
    Midwest
    2020 Prius Prime
    Yes, all else works from what I can tell. We have backup methods for most things since Bluetooth and the car’s navigation system worked, so it’s just a minor inconvenience.
  5. sam spade 2
    7,035
    2,804
    2017 Prius c
    But if you are under warranty, you SHOULD get it fixed.
    It may get worse later.
    Northerner likes this.
  6. Northerner
    121
    103
    Midwest
    2020 Prius Prime
    N
    We are about a week past warranty, but I’d have fixed it anyway. The good news is that all of the ports started working again- on their own! I have no explanation.
  7. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    If it's an intermittent problem, that's going to be a problem for the repair shop to diagnose and fix.
  8. Northerner
    121
    103
    Midwest
    2020 Prius Prime
    Yes, I agree. One thing that may or may not have helped was that all started working again after powering up the induction charger. That worked and so I tested the USB ports and now they worked, too. They had not worked last time I had used the car on the previous day.
    I just include this last bit for anyone else to try should they experience the same issue and read this.
