USB Song List
Discussion in 'Gen 4 Prius Main Forum' started by ocean view, Jan 30, 2024.
  1. ocean view
    ocean view Junior Member
    27
    Western MA
    2022 Prius
    My USB song list displays each song twice. Has anybody found a solution to fix this? There are some old posts on this topic but no fix that works.
    2022 LE
  2. kevinwhite
    kevinwhite Active Member
    330
    199
    Los Gatos Ca
    Are you creating the USB stick on a Mac?
    Do half of entries start with a period (".")?
  3. ocean view
    27
    Western MA
    2022 Prius
    Yes on both.
    Tunes run through an MP3 converter on macbook.
  4. kevinwhite
    330
    199
    Los Gatos Ca
    MacOS copies hidden resource files at the same time as copying the intended file, they all begin with a period. Unfortunately Toyota tries to display and play those files.
    You need to remove those files beginning with a period from the USB drive
    You can either do this using macOS terminal or by giving the command, shift period command allow the hidden files to be seen and removed using finder.
    Kevin
  5. ocean view
    27
    Western MA
    2022 Prius
  6. ocean view
    27
    Western MA
    2022 Prius
    Thanks Kevin..... I gave it a try but to no avail. I tried both methods and the hidden files kept coming back.
  7. kevinwhite
    330
    199
    Los Gatos Ca
    Weird.
    Don't understand that.
    I don't have a Prius at the moment so I can't test it.
    I have an MP3 player that I use that also exhibits similar issues and deleting the hidden files works on that. macOS seems to have changed in the last year or so in what it does with the hidden files.
    kevin
