USB Stick/Music
Discussion in 'Gen 3 Prius Audio and Electronics' started by mr estrada, Apr 26, 2013.
  1. mr estrada
    mr estrada Junior Member
    43
    I recently purchased a USB stocked filled it with music and as I'm scrolling through my music and about less than 5seconds into the Song the audio just turns off.? Anyone experience this?
  2. calvin mcgill
    calvin mcgill Junior Member
    I have an issue when I use my iphone and play a podcast. It plays for a couple of seconds then resets the usb interface. I'm still trying to figure out what is up with the stereo. Have you tried a iphone or mp3 player?
  3. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    This happens to me every once in awhile but it's rare. I just try again or unplug and plug in again.
  4. jgilliam1955
    368
    102
    Williamsburg, Virginia
    Check the setting on the screen under options. Something may have to be unchecked.
  5. mr estrada
    43
    i havent tried an iphone/mp3 plugged in directly into the USB slot but i can give it a shot and see what happens...i'll report back in a few.
  6. mr estrada
    43
    do you know exactly what settings under options i need to have checked?
    this has happen almost every time i use my USB stick to listen to music, it's a 16gig Kingston DataTraveler 101 USB 2.0.
    it's pretty annoying to be in a middle of a song then the system shuts off and the screen says "audio off" as if i hit the power button to turn off my music.
  7. bathala
    bathala Member
    128
    30
    Area 52
    When the USB device is pulled from the port, the screen will show "Audio Off". Kingston DT is one of those flash drives with a flip cap. See if there's something near the flash drive that might be bumping it and causing it to get loose from connection. I would recommend a low profile micro USB flash drive to use instead.
  8. mr estrada
    43
    that's the thing, i don't have anything in the compartment other than the USB stick and a AUX cable...err...
  9. kyle5434
    kyle5434 Junior Member
    37
    Nebraska
    Something similar happens to me occasionally, though I have an iPod Classic plugged in via USB rather than a thumb drive. When it happens, it's usually about 10-15 seconds after turning the car on - the radio unit goes to "Audio Off" - and it doesn't clear itself until I shut off the car (not just the radio unit) and turn it back on. If I don't turn the car off, I can still power the radio unit back on and play a CD or listen to the radio, but the USB connection is dead until I power-cycle the car.
  10. bathala
    bathala Member
    128
    30
    Area 52
    Try using a different flash drive to isolate the problem.
  11. FranklinS
    FranklinS Ach crivens ye scunners!
    190
    94
    Eugene, OR
    Does the head unit show the USB connection at all or lighted after it shuts off? The USB in the Prius 2 is fussy IMHO. I tried two different class 10 Sandisc and a couple of other class 6 flash cards in various configurations and all failed immediately or eventually (two weeks). I have heard it said that if you use too big a memory capacity or too filled up with data it messes it up. I ended up trying a cheap, tiny, PNY 8 gig small fingernail sized drive and it has worked perfectly for the last 2+ months.
  12. sr1
    sr1 Junior Member
    charleston, sc
    Prius- 2013, Using music from USB-
    I have a similar question- except
    How do I fast forward music, while playing using usb-thumb drive. I tried to slide on the touch screen, does not work. Toyota dealer in South Carolina says- touch screen is the way (just like while playing using blue tooth-Smart-phone). I have to wait for each song to complete, cannot start within a song!
    Any work arounds, let me know please.
    Thx,
    SR
  13. qdllc
    qdllc Senior Member
    1,358
    396
    I don't believe you can.
    You can jump to the next song, repeat it if you quickly press back once, but there's no "jog" to music playback. It'd be a nice feature, but since it would best be done via touchscreen and that would encourage fiddling with the radio rather than focusing on the road, I'd not expect Toyota to ever offer that feature. Maybe if you went to an aftermarket head unit, but I don't know if you're looking to do that type of "mod."
  14. mmmodem
    2,732
    1,703
    Bay Area, CA
    Hold the next button to fast forward. The previous button will also rewind. This works for BT connected audio as well USB audio.
  15. qdllc
    qdllc Senior Member
    1,358
    396
    Ohhhh. I'll have to try that. :)
  16. qdllc
    qdllc Senior Member
    1,358
    396
    The press and hold worked, BUT only on the head unit. :( Doing the same on the steering wheel resulted in the music skipping to the first song in the previous or following folder on the USB drive. Odd. It makes more sense for the steering wheel switch to do the same as the head unit so you don't have to take your hands off the whee.
  17. mmmodem
    2,732
    1,703
    Bay Area, CA
    The steering wheel controls seek same as the headunit for me.
  18. qdllc
    qdllc Senior Member
    1,358
    396
    What year and level of Prius? I have a 2013 Prius Two.
  19. mmmodem
    2,732
    1,703
    Bay Area, CA
    Oh, we have different headunits. I have a base PiP which is equivalent to a trim 3 Prius with navigation and Entune. That might explain it.
