Use 185/65/r15 tires on Gen 3?
Discussion in 'Gen 3 Prius Main Forum' started by alexmessinger, Nov 12, 2017.
Tags:
  1. alexmessinger
    alexmessinger Junior Member
    vermont
    Can I use the snow tires from my old gen 2 prius (185/65/r15) , on my 2011 prius (spec is 195/65/r15)?
  2. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Yes you can. The overall dynameter size difference is small so the speedo error will be small. For what's it worth, a few years back, I bought used snow tires for my son's former 2006 Prius. They were both 185 and 195 size tires. I still have the tires and could use them on my 2013.
  3. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    They will probably work, but I'd check the "load rating" to make sure it is close to the 195/65/r15 rating on the summer tires. Size isn't everything. ;)
