Use your 240v Dryer outlet?
Discussion in 'Prime Plug-in Charging' started by PrimeRN2019, Apr 15, 2019.
  1. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    OK, if you have an available 240v Dryer Plug, you can build your own ~$20 dollar Dryer Plug by studying my pictures or you can buy a pre-made ~$50 conversion plug from Amazon.
    As soon as you do this, your 100% charging times will drop down to about ~2:25 hours/minutes.
    Rob43
    #41 Rob43, Apr 27, 2019
  2. krushmoto
    krushmoto Member
    65
    44
    US
    Here's what I did.
    My laundry room is right next to my garage so I purchased 10/2 extension cord and cut off the ends. I tapped into the dryer line (pic 1) and ran the extension cord through the wall into the garage and boxed it in a single receptacle box (pic 3) w/ the appropriate receptacle for my level 2 charger. Total cost about $30. 220V receptacle was only $3 but the 10/2 extension cord was expensive. Already had the outlet box on hand.
    I regularly run the dryer and charge the car at the same time and the circuit breaker has never tripped. Telling me both together are not pulling enough power at the same time to trip the circuit.
    BTW I put in a junction box (pic 2) in the garage so I can power my 60 gal air compressor. I just make sure everything runs individually. 1557706983404.jpg IMG_20190512_202409038.jpg IMG_20190512_202429056.jpg
    moto z3 ?
  3. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Salamander_King likes this.
  4. krushmoto
    krushmoto Member
    65
    44
    US
    Rob is correct, don't use regular "extension cord.". I used a contractors grade wire that's outdoor rated and double insulated but this only a temporary install. Planning on a remodel where the charger will get a dedicated circuit.
    moto z3 ?
  5. Marine Ray
    Marine Ray Senior Member
    1,139
    949
    Sparks, NV
  6. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Extension cords are multi-strand wire, they're good when flexibility is needed.
    Solid copper wire is best when doing a (non-moving) permanent installation, like wiring your home.
    Rob43
  7. Marine Ray
    1,139
    949
    Sparks, NV
    Thanks. Appreciate the feedback. Silly question and observation - if the extension cord will not be moved (i.e. permanent installation), is an extension cord OK to use? Also, understand the charging cable provided by Toyota cannot be made with solid copper wire due to the need for flexibility. However, that Toyota supplied charging cable seems to work well and is in effect an extension cord.
  8. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    You're welcome.
    As much as I like a great quality 12 or 10 gauge extension cord for some applications, I will defer to one of our many Prius chat Electricians for the best answer.
    Rob43
  9. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    The electrical code does not allow for flexible wire to be exposed on a wall or within stud bays (i.e. Romex). Extension cord wire is not approved in any section of the code. If you surface mount wires, they must be in either armored cable or conduit. Your photos show multiple instances of non-compliance with the electrical code. Here is an example of a proper surface mount installation:
    Rob43 and Salamander_King like this.
  10. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Why would you buy a 10-2 extension cord and cut off both connectors instead of just buying the needed length of 10-2 wire??
