Used 2010 Prius , help understanding Toyota notes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sweetgreen02, Apr 19, 2015.
  1. Sweetgreen02
    Sweetgreen02 Junior Member
    Denver
    I contracted to purchase a vehicle but I am wondering of I should follow through. It looks like it has recently had some issues but I need help determining of the issues are serious. I need to pay 5k to get it.
  2. Patrick Wong
    18,200
    6,474
    I would be concerned that the engine overheated in March 2015. An all-aluminum engine will not withstand much abuse.
    If you are serious about buying this car, the engine compression should be checked (or a cylinder leakdown test performed), and the engine oil and engine coolant should be checked to make sure there is no intermixing of engine fluids. Make sure that no current DTC are being logged by any of the car's ECUs.
    There is also mention of a battery being replaced in November 2014. Is this just the 12V battery; or is this referring to the high voltage traction battery?
  3. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    It might have the infamous EGR issue - where the carbon is built up in the EGR passages and the valve itself.
    It may be difficult to verify this, but this engine may have an oil consumption issue if the previous owner complained about the oil level to the dealer.
    And as Patrick says, this engine may have overheated more than once. This car may be one to pass on.
  4. Former Member 68813
    3,524
    981
    US
    OP: please redact the image and remove the VIN and owner info.
    this only a good deal if very cheap for a project car. 200,000 miles on a water pump is actually not bad. i wonder if there were any warning signs. not having access to temp gauge sucks.
  5. Mendel Leisk
    38,718
    Ok, try again, OP's images, cropped and contrast raised a bit:
    74377_image.jpg 74378_image.jpg 74379_image.jpg 74380_image.jpg 74381_image.jpg
    #5 Mendel Leisk, May 17, 2015
  6. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Walk away from this one Sweetgreen02. She's done.
  7. bisco
    49,469
    i hope it's not too late...
