Used 2012 Prius Four MPG newbie question
Discussion in 'Gen 3 Prius Main Forum' started by Stephan Jefferson, Sep 19, 2019.
  1. Stephan Jefferson
    Stephan Jefferson New Member
    Long Beach, CA
    Hello everyone,
    I got the vehicle to go and when I fill it up it only says I have about 300 miles. I believe it has to learn how I drive before it gives me an accurate estimate how many miles I will get out of a tank. Am I correct?
    I'm averaging about 60 miles per gallon (I'm getting this from the consumption breakdown).
    Can someone please tell me if I'm doing something wrong or I just have to be patient?
    49,392
    patience grasshopper :) that's based on past driving history. it will likely take a few tankfuls
    welcome, and all the best!(y)
    Stephan Jefferson and Grit like this.
  3. MelonPrius
    MelonPrius Senior Member
    819
    508
    Las Vegas
    Averaging 60 mpg? Then there's nothing to worry about. Just keep an eye on your fuel gauge and when it starts blinking, you have roughly 2 gallons left so fill up.
    mikey_t, Stephan Jefferson and bisco like this.
  4. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    It will never consistently accurately show miles you have left, because it doesn't know how or where you will drive in the near future. It is just a conservative rough estimate. Don't take it too seriously!
    The Electric Me likes this.
  5. Stephan Jefferson
    Long Beach, CA
    Thank you all. I'm trying to get in the 700 mile club
    jerrymildred and bisco like this.
  6. bisco
    49,392
    keep at it, you'll get there. but the true measurement is at the pump, not the dte
  7. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Right, and the fuel level gauge is a more useful tool to help you get there.
    jerrymildred likes this.
  8. Stephan Jefferson
    Long Beach, CA
    Please elaborate
  9. bisco
    49,392
    when you fill up, divide miles driven by gallons pumped. keep records and make a graph for future reference.
    that is more accurate than dte
  10. Gliderguy
    Gliderguy Junior Member
    46
    Prescott Valley, AZ
    I also have a 2012 Prius four. I currently have 185,000 miles on it. There is a website called fuelly.com and that is where I log my gallons and miles. I write the trip mileage on each gas receipt and then I have both numbers. you can see long term averages, winter driving usually costs a few MPG due to a more volatile blend of gasoline and additional warm-up time for the engine to reach temperature. Ditto for wet weather, rain puddles drain away economy. I was averaging 47 mpg in my 93 mile commute (with a 4000 ft elevation difference). I blew a head gasket, and repaired it myself. (big job, took me two weekends) On the three tanks since, my average is right at 50 mpg. This is with about a quarter of road being 75 mph, about half 65mph, and the remainder 55 or less. I use both Torque and Dr Prius. Torque probably saved me from wrecking my engine totally until I was sure I had a head gasket issue. I could see overheat minutes before the red overtemp light would come on, and I could already be planning a safe stop to add coolant.
