Used Inverter?
Discussion in 'Gen 3 Prius Technical Discussion' started by Taxi/Limo, Nov 28, 2022.
  1. ChapmanF
    18,997
    If you like the TRW patent (1971, but likely the one you're thinking of), see how clearly you can recognize the basic idea (with the planetary connections rearranged a little and some other minor differences) in John Godfrey Parry Thomas's patent filed in 1908.
    Then think about, if you were going to build the MG ECU using technology available in 1908 (or even 1971), what size room would you need?
    To say nothing of the IPM. At least in 1971 there were transistors, but there weren't small IGBTs that could switch a hundred amps.
    The simplest vacuum tubes were four years old in 1908.
    An overview of the math the MG ECU is doing for you can be found in this post.
    #21 ChapmanF, Nov 30, 2022
    Taxi/Limo likes this.
