Used Prius with check engine light on?
Discussion in 'Gen 3 Prius Main Forum' started by scooby, Mar 5, 2022.
  1. scooby
    scooby New Member
    uk
    I saw a used 3rd gen 09 prius that is cheaper than the market price at the moment but it has got the check engine light on. The seller says it has the codes P0102 (Mass air flow circuit low) and P0113 (intake air temperature circuit input high).
    What could the issue? Is it worth taking the risk that it could be an easy fix or is that not likely?
    Thanks
  2. JC91006
    16,477
    8,394
    Best to do your own due diligence on what is wing with that car, what the seller says is not always the total story.
    when gas prices are really high and there is a cheap economic car for sale, you should be very cautious as to why it’s for sale
  3. ChapmanF
    15,480
    Those two inputs are built into one sensor assembly that lives on the top rear of the air box, just where a large duct comes off it at the left. If those are the only two codes, before anything else, pop the hood and see if that sensor is plugged in.
  4. PriusCamper
    PriusCamper Senior Member
    11,065
    4,504
    Pacific Northwest, USA
    Yes, If I were you I'd find a friend with this sensor and borrow it and pop it in and take it for a test drive after you've agreed on lowest possible price. They won't be happy to see you fix it so easily, but it's also likely that you might find other issues with it.
