Using car as generator for house power
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ED9593, Oct 31, 2012.
  1. bear15
    bear15 Member
    168
    36
    Suburban Chicago
    Fantastic! This is very helpful and my family also thanks you.
  2. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    I bought my 1K pure sine wave inverter for $260 (Xantrex Prowatt SW 1000 from Northermarine on eBay).
    bwilson4web likes this.
  3. Randy B
    Randy B Member
    104
    30
    NH
    Try googling "Prius as Generator". There are higher power options available, too.
  4. Randy B
    Randy B Member
    104
    30
    NH
    I have used 2, 3 and 4kw inverters on the Prius hybrid battery [see converdant.biz/plug-out]. The 12v 1kw solution maxes out at about 1k. Still 1kw is usually good for the fridge, TV, lights, computers, network and phones. PSW [pure sine wave] is best for appliance longevity and efficiency.
  5. Randy B
    Randy B Member
    104
    30
    NH
  6. joerockt
    joerockt Junior Member
    97
    27
    This is all pretty fascinating to me. I think I've learned a lot here. If I'm understanding everything correctly, in a pinch I can use a 1500w inverter, connect it to the 12v battery and power items in my house off of it. But if I need more wattage, I will need a larger inverter that would connect directly to the hybrid battery.
    I don't think I'd have a problem connecting the inverter to the 12v battery, but the HB inverter connection looks a bit more involved. Does anyone make a kit and/or do the work in SoCal? This would definitely step up my disaster prep game.
  7. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    You got it all right ... you may want to go for a pure syn inverter to minimize loss on the 110V side but pretty much it.
    Just like to point out that some appliances may have some gotchas because of the inrush current (mostly stuff with big motors like fridge or A/C pumps). I had some issues with that but further information provided here.
  8. joerockt
    97
    27
    Did you find a work around to this? Much less useful if I can't hookup a refer or window AC unit.
  9. gliderman
    gliderman Active Member
    751
    225
    Buy a generator with enough power to handle A/C motor starting.
  10. joerockt
    97
    27
    Thanks for the useless comment. Plenty of these already in this thread. I already have a 3kw briggs and stratton. I'm looking for a more efficient and quieter way to do this, which is what this thread is about.
  11. gliderman
    751
    225
    The Prius isnt it. But you go right ahead and give it a try. Good luck!
    GrumpyCabbie likes this.
  12. techntrek
    techntrek Member
    263
    84
    MD
    I'd stick with a 1000 watt inverter, tops. The DC-DC converter in the Prius can only handle that draw, anything above that must be temporarily supplied by the 12 volt battery. Inverters usually can supply a surge of 50% to 100% above their rating so a 1000 watt inverter will already be able to push things above the limit. Going with a 1500 watt inverter could go way over the top.
  13. techntrek
    techntrek Member
    263
    84
    MD
    About the smallest A/C you are going to find is a 5000 BTU unit, and 1500 watts surge is unlikely to start even one of the newest most efficient models. Remember the hotter it is outside the harder it is to get the compressor moving. You might get it running with 2000 watts, but to get to that level you need to tap into the traction battery, either with the Converdant solution or the APC solution. Then of course you can go much higher.
  14. Randy Bryan
    Randy Bryan New Member
    Concord, New Hampshire
    Look up ConVerdant. They can find installers in So Cal.
  15. techntrek
    techntrek Member
    263
    84
    MD
    Your quick dismissal of other solutions on the Using PIP As A Generator thread suddenly has become clear. I repost this here as a warning that Mr. Bryan has a bias that the rest of us don't.
    A quick Google search reveals that Converdant is owned by.... Randy Bryan.
    ftl and WE0H like this.
  16. techntrek
    techntrek Member
    263
    84
    MD
    New info for anyone looking to tap their traction battery - additional brands/models of UPS, and an inverter, that are compatible with the Prius traction battery. I added the info to the end of the thread linked in my signature.
    WE0H likes this.
  17. techntrek
    techntrek Member
    263
    84
    MD
    Loving my Prius today - massive ice storm, tons of trees and limbs down, lost power at 2:21 am and switched over from my big generator to my Prius around 6. Neighbors have stories of being out for 2 weeks after an ice storm and I would bet it will be days before we get it back this time. Have everything running - lights, TVs, DVRs, furnace and wood stove fan. Go Prius Power!
    WE0H and DadofHedgehog like this.
  18. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    It's true when they say drugs ruin lives.
    What they don't say is that it isn't necessarily the drug users life!
  19. bisco
    52,891
    although, it was for phillip seymore hoffman.:(
  20. techntrek
    techntrek Member
    263
    84
    MD
    Ya'll on the wrong thread?
