Using heat tanks mpg, alternative?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ppimd, Nov 9, 2012.
  1. ppimd
    ppimd Member
    122
    Maryland
    This time of year, my wife automatically turns on the PPI heat when getting in the car.This drops the mpg into the 40's, driving around suburban-urban streets. Any work-around?
  2. mrbigh
    3,686
    699
    Long Island, NY
    Show her how nice the seat warmers are.
    Netherland plug-in and lensovet like this.
  3. schlem
    schlem Polygeek
    82
    39
    Ballard, C@L
    Dress in layers. :ROFLMAO:
    lensovet likes this.
  4. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    If she can stand it she can turn off the heat while stopped at a red light - if the engine isn't very warm it will run when the car is stopped because of the call for heat. Grill blocking helps here too.
    Also you can use ECO mode to lower the temp at which the engine shuts down when calling for heat, and also keep the airflow going to 'feet-only'.
    Netherland plug-in likes this.
  5. tiggerntatie
    tiggerntatie New Member
    17
    New Hampshire
    Gasoline is a better energy source for producing heat than electricity, so it makes sense to run the ICE for that purpose. I'm seeing mileage in the 40s for very short trips in this weather, but the long term mileage is still hitting 85 or so, so I'm happy.
  6. AHetaFan
    AHetaFan Member
    104
    55
    I like seeing 999 as my mileage for local trips around town when I turn off the car at my destination. To get this in cold weather the first two posts nailed it. I find the ICE stays off and I am comfortable even in 20º - 30º mild winter temps with the electric seat heater on and climate control set to off. No matter what car I'm going to be in I wear a hat, jacket and gloves in this weather when I leave the house. The seat heats up immediately keeping my core warm so I am comfortable through the duration of EV range. If electric seat on low or high is not sufficient I turn on the climate control once EV range is used up.
    If the engine starts before you get the climate control turned off just turn the car off again to stop the ICE then power back on and drive away.
    The near instant heat provided by the Prius electric seats has me more comfortable starting out in the morning than any car I have ever owned before including my last one with heated leather seats.
    Using a garage or covering the windshield with a cover prevents the need to clear ice from the windshield before you leave home but sometimes you just need to burn some gas and use climate control to deal with wet weather or colder winter conditions (y)
  7. bisco
    52,904
    i haven't used the heat yet, unless i know i'm going waaaaaaaayyyy beyond ev range.:p
  8. retired4999
    2,652
    627
    Eau Claire, Wi.
    Let it run a little every day just to make sure it still can! :D
  9. bisco
    52,904
  10. Edsvfr800
    Edsvfr800 Member
    67
    30
    Franklin wi
    have your wife sit in the back seats so she can't touch your controls....:)
  11. retired4999
    2,652
    627
    Eau Claire, Wi.
    Controls, controls, WHAT CONTROLS! :D
  12. ntucker
    ntucker Junior Member
    30
    Our problem is the two kids in carseats in the back. Warming mommy's butt doesn't stop the crying about the cold. :) The heater in this car has been quite a disappointment in terms of killing gas mileage -- when it's cold, we seldom get better mileage than a regular Prius, despite having a full charge every day.
    PlugInPriusNH and delrey like this.
  13. Edsvfr800
    Edsvfr800 Member
    67
    30
    Franklin wi
    On short trips..... 3 to 5 miles... I tell my wife that the engine will not provide adequate heat anyway...so just use the seat heaters. So far this method has worked for me.
  14. bisco
    52,904
    how far do you typically drive?
  15. ntucker
    30
    Usually pretty short trips. The longest typical trip is about 10.5 miles round trip and before the winter, we could almost always squeak it in on pure EV. Obviously, the mileage of the car changes drastically if your trips change from 100% EV to what seems like having the engine running just to keep itself warm about 50% of the time.
  16. bisco
    52,904
    that's true. if you only go 10-20 miles and want heat all the way, the batteries aren't helping a ton, but you should be getting 80-90 mpg, not 50-60 like a regular hybrid. ymmv.
  17. ntucker
    30
    Definitely not 80-90. The other day, as an experiment, I drove that 10.5 mile round trip (which is almost completely flat) with the heater set to 72 in 46° weather. I drove like a little old lady (keeping the power bar well under half) and got 54mpg for the trip. Should I be concerned that something is wrong with the car?
  18. ntucker
    30
    Out of curiosity, does there exist an engine block heater that could use the car's internal power so that there's not an additional cord to run when it's plugged in? I went and got the EVSE setup all buttoned up and finished off nicely so it's super convenient, and having to plug another cord in (especially one that takes both hands, such as plugging a pigtail from the car into an extension cord) while wrangling a toddler and a baby would definitely be a hassle for my wife.
  19. retired4999
    2,652
    627
    Eau Claire, Wi.
    Car is fine. Try this, car in ev mode, eco mode, Temp setting 65 degrees, fan speed setting 2. Now drive your normal route of 10.5 miles round trip, you should be able to get about 80+ mpg!
  20. bisco
    52,904
    there is no engine block heater like that. in your experiment, were you in ev or hv mode?
