Using Noalox? (Hybrid Battery Reconditioning)
Discussion in 'Gen 2 Prius Technical Discussion' started by Roberto Z, Aug 1, 2025.
  1. Roberto Z
    Roberto Z New Member
    Hello, new to this forum and doing my first DIY Hybrid Battery Reconditioning project on a '06 Gen 2 Prius.
    Found a lot of corrosion around the nuts and bus bars when taking the pack apart and have read mixed reviews on whether or not using products like Noalox (anti-corrosion compound) or dialectical grease on the connections when I reassemble would be helpful or not?
    I soaked the nuts and bus bars in a vinegar bath which did a great job at cleaning them up. Still trying to make a final decision on the Noalox though so any insight or suggestions would be much appreciated. Thanks.
  2. Tombukt2
    Tombukt2 Senior Member
    13,875
    2,521
    Durham NC
    Are the nuts and really clean in vinegar only I never thot so I tumble em or replace . I use a spray didn't even think of noalox I have plenty here it's not been used for years now as slum changed 25 yrs ago or so. It conducts so I guess worth a try . It's a past so flying sir thru case stuff could pile up on it possibly
  3. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Hello, I have a related question. Battery technology is evolving all the time. I'm sure that we'll have the option to upgrade to newer and better batteries, and I'm sure that some companies are developing batteries with the form factor suitable for a Prius. Let me know if this is true.
  4. Tombukt2
    13,875
    2,521
    Durham NC
    Yeah they pop.up on market place every other day . Issue is so far all of em make a out 8 to 16bminths and fail . The Panasonic has reliably made 8 to 10 years pretty steadily for the 20 years of the manufacturing cycle so you know kinda tricky giving up that reliability. For some newfangled nonsense that won't be here tomorrow. And the cost is always very close to the original you're saving very lil
  5. PriusTech
    PriusTech Active Member
    264
    133
    Reno
    Sodium Ion battery for Prius $1900
    Toyota hybrid battery upgrade pack– NexPower Energy
    This company had previous new tech batteries that failed early but they back them by selling you this newer battery at a deep discount. It remains to be seen if it's viable, it hasn't been tested for very long. It has more power and it's 30% lighter.
    I don't see why a better battery can't be developed, the NIMH type in the Prius has been surpassed for a long time in the hobby sector. And the Chinese have a new EV battery that charges a 200 mile capacity in just 10 minutes
    #5 PriusTech, Aug 1, 2025
  6. Tombukt2
    13,875
    2,521
    Durham NC
    Must be something to this because I've seen an Asian company offering a sodium upgrade too so will win over all been tried . It's kind of hysterical they're having same issues on volt forum
  7. PriusCamper
    PriusCamper Senior Member
    13,475
    5,441
    Pacific Northwest, USA
    I also use a rock tumbler to clean hardware...
    As for the anti-corrosion electrical grease it's a huge mess next time you have to take the pack apart and corrosion begins through the seals where threaded terminal comes out so its very difficult to treat the areas that most need the grease. And maybe if you were putting a brand new pack that you won't see for a decade or longer, it'd be wise, but anything old you'll be working on again in coming years, don't do it!
    Also you can get 10% off if you use my link in signature below for new nuts, busbars and voltage sensing harness... Make sure to look inside battery ECU for corrosion too... But how thorough you want to be has more to do with the pack's lifespan on a spectrum of all newly replaced modules with brand new on one end, to a pack that's mostly made up of used replaced modules. Most people on here won't bother once they've replace one or two bad modules with a matching used on because the reliability goes town if you don't have enough modules to choose from.
    gdanner and Roberto Z like this.
  8. Roberto Z
    Thanks, I was kinda leanin' towards NOT using the Noalox or any kind of grease so that may be the way I go. Fixing it up to try and sell, so basically just trying to get it running again and in as good a shape as I can without putting a whole lot more into it.
    Found 3 bad cells and the rest still seem pretty strong (ie. almost all read 5500mAh and up and a lot over 6000 too).
    Thanks for the tip too on checking the ECM for corrosion too. I hadn't thought about that but do remember reading about others running into that, so adding that to my Checklist. :)
  9. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I find that a brass rotary brush on a Dremel does the least damage. It takes off corrosion without gouging the metal coating too much.
  10. ChapmanF
    19,055
    What's everybody's favorite dialectical grease? Apparently, Heidegger liked a Gutedel from the Markgräflerland region.
  11. Mendel Leisk
    42,374
    Geez chap, you're taking on @Prodigyplace's role.
    Depends on the situation, but for spark plugs and electrical connections, I consider how the car came from the factory, figure to follow suit. It might be just to save money/time, but still, I tend to follow their lead.
    A contrarian case: I do like to butter up the suspension components/bolts, with something to ward off rust. Using boiled linseed oil for that.
    #11 Mendel Leisk, Aug 2, 2025
  12. Prodigyplace
    12,720
    11,852
    Central Virginia
    Huh??
  13. Mendel Leisk
    42,374
    Typo squelcher. :)
    Prodigyplace likes this.
  14. ChapmanF
    19,055
    But I like that typo!
    Prodigyplace and Mendel Leisk like this.
  15. PriusCamper
    13,475
    5,441
    I bought one in that comes in spray can... Way less stupid to apply that way, but still a stupid thing to do that you'll realize next time you take the pack apart and can't get an easy grip on anything because all that stupid grease is in the way!
  16. ChapmanF
    19,055
    Sounds like the grease you're talking about might be the dielectric kind.
    Dialectical grease might come more often in bottles, cans, or kegs.
  17. Hayslayer
    Hayslayer Active Member
    539
    331
  18. PriusCamper
    13,475
    5,441
    I'd be happy to mail it to anyone who wants it...
    But it doesn't speak, let alone in a dialect... So know chance in having a logical conversation with it...
  19. ChapmanF
    19,055
    I just figured dialectical grease would be something that helps dialectics go more smoothly.
    PriusCamper likes this.
  20. Carall
    Carall Active Member
    316
    104
    Harrisonburg, VA
    The greasing does not prevent the copper busbars from turning black.
    T1 Terry likes this.
