Using oil - no smoke?
Discussion in 'Prius v Technical Discussion' started by priifamily, Jul 2, 2017.
  1. priifamily
    priifamily Junior Member
    banning, ca
    My 2010 Prius has 275,000 miles. I took it to my mechanic because of the declining miles per gallon and oil loss he changed perhaps the gaskets however the oil loss is still occurring.
    Any ideas on this?
    Thanks
    TD
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,104
    6,967
    Texas Hill Country
    There are threads on the subject here. Some think a pcv or egr valve will help.
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    And a LOT of others think that at 275,000 miles, the engine is just wearing out.
    Try using a heavier weight of "high mileage" oil and start shopping for a new car.
    Seriously.
  4. priifamily
    banning, ca
    Gracia's Amigos
    The rest of the vehicle seems good.
    I am thinking of replace an engine w a lightly used one.
    Do those engine swaps work out or is the tranny or something else next?
  5. bisco
    52,855
    how much oil are you using, and how far have your mpg's dropped?
    Raytheeagle likes this.
  6. 04priusnow
    04priusnow Active Member
    345
    201
    like other have said.. pcv replaced egr, egr cooler.. either replaced or cleaned.. also install a oil catch can to help prevent oil buildup in these components
    Pixel XL ?
  7. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    At that mileage, you probably have worn out critical engine internal components(piston rings, etc).
    I have had a similar experience with a gen2.
    Has got no smoke coming out, but consumes almost 2quarts of oil a week. Wasnt funny. Had to opt for engine rebuild, instead of replacing the engine.
    You could get a low mileage engine, and swap. It wouywork. In our case, we ereylookjng at the cost of a used replaced engine.
  8. priifamily
    banning, ca
    That sounds about right & is where I am at also the mileage is only about 35 miles per gallon
  9. bisco
    52,855
    i've seen worse, relax and enjoy.
    tvpierce and Raytheeagle like this.
